8 minutes ago, PoPPinjoker0207` said:
Oh Well I Can't Really Find A used Because They Are Overvalued
Don't worry, it is NOT a fire hazard. But you could get this one instead: https://pcpartpicker.com/list/3pksnn It is only couple of dollars more expensive and it is quite a bit better (according to JohnnyGuru).
ZamoRIG 2.0:
Processor: AMD Ryzen 7 1700 @ 3.9GHz
Cooling: DeepCool Captain 240 RGB + 2x Corsair ML120 fans
Graphics Card: Gigabyte GTX 1070 G1 Gaming x2
Motherboard: Asrock X370 Gaming K4
RAM: 2x8GB DDR4 G Skill Ripjaws V Grey @ 2800MHz
SSDs: 2xPatriot Ignite M.2 240GB
HDD: WD Black 1TB + WD Green 2TB
 PSU: Corsair RM750
Case: Corsair Carbide 400C
ZamoRIG “Portable”:
Processor: AMD Ryzen 5 1600 @ 4GHz
Cooling: Corsair H80i
Motherboard: Gigabyte AB350N Gaming WiFi
RAM: 1x16GB DDR4 Corsair Vengance  @ 2400MHz
SSD: Patriot Ignite M.2 240GB
HDD: 2TB 2.5” Seagate HDD
PSU: Corsair TX650M
Case: Siverstone SG13
https://linustechtips.com/topic/695803-pc-help/#findComment-8912761
