Hey Guys,
I'm running on:
i5-4590, 3.3ghz
8gb, ddr3, 1600mhz, c10
Asus gtx 1070 (previously gtx 960)
Asrock h97 pro 4
Windows 8.1 Pro
Game intended : Overwatch
The Issue:
On the techspot site, 1080p, ultra settings, fps=200+
My rig, on low settings 110-130 fps and minor spikes, not smooth.
Whats weird is when i'm on training mode or 1v1, my fps can go 250-300fps.
Stuff I've attempted:
1) Ensured overwatch is on optimum settings (e.g. rendering 100%, 1080p resolution, etc.) and nvidia physcX set to gpu or auto.
2) Ensured motherboard drivers are up to date
3) Attempted backdated clean installation of nvdia drivers, non of the versions seem to help.
4) Used throttlestop on my processor.
5) temperatures on cpu and gpu are low (i.e. 50 degrees celcius, etc.)
Help.. please:
1) Should I just add another 8gb ram? (The same ram model) or change to a c8 ram?
2) Change to windows 10?
3) Change my motherboard to cater for a faster ram.
4) Get an i7-4790k @ 4.0ghz, if yes, do I need more ram?
5) Get a whole new rig?
6) Any other options/solutions?
Please and thank you in advance :)!
https://linustechtips.com/topic/695685-gtx-1070-fps-help/
Disable Windows Indexing
Disable Windowa Defender
those things eat a lot of resources
And yes, definitely buy another 8GB of RAM. The amount you have is kinda low for gaming.
i7 4790K || R9 290X + R9 290 || 16GB G.Skill TridentX 1866 || Gigabyte Z97MX Gaming 5 || Crucial MX100 256GB || WD Caviar Blue 1TB
https://linustechtips.com/topic/695685-gtx-1070-fps-help/#findComment-8911349
6 minutes ago, Andrew91 said:
Help.. please:
1. If you want to.
2. Not unless you want to.
3. I wouldn't recommend that. Faster RAM does not mean more frames.
4. Not unless your CPU is at 100% all the time, if it is then sure.
5. That seems expensively pointless.
6. Check your temps on your GPU, it may be thermally throttling, update your drivers, etc.
https://linustechtips.com/topic/695685-gtx-1070-fps-help/#findComment-8911367
4 minutes ago, Dawson Wehage said:
Maybe if you want upgrade the process to a i7 or a skylake 6600k
It would add like 5 fps.
https://linustechtips.com/topic/695685-gtx-1070-fps-help/#findComment-8911372
1 minute ago, Dawson Wehage said:
eh its always nice to upgrade. stay ahead of the horse you know?
Is it? There are cases where the gain from upgrading is nil. In these cases it's just a pointless waste of money.
https://linustechtips.com/topic/695685-gtx-1070-fps-help/#findComment-8911412
11 minutes ago, Dawson Wehage said:
horse
newer =/= better
A 4 year old i7-3700K paired with a 1080 beats a brand new i5-6600 with a 1070 any time of the day.
https://linustechtips.com/topic/695685-gtx-1070-fps-help/#findComment-8911509
1 hour ago, Mykie said:
I can't exactly think of an issue on top of my head, but by looking at the RAM, 1600 Mhz is kinda... slow? I could suggest you to get more ram with faster speed. For one thing, what settings do you have for OW? Completely maxed out? AA?
I just used the presets in overwatch, ultra which had maxed almost everything, I have even tried low settings, and the fps goes from 90-160fps.
Would chucking in another identical ram to make it 16gb help?
https://linustechtips.com/topic/695685-gtx-1070-fps-help/#findComment-8911802
Im not sure i understand your Problem. Whats wrong with 110fps?
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/695685-gtx-1070-fps-help/#findComment-8913844
Check the RAM usage. And Tell me how many RAM is being used with windows itself and OW.
https://linustechtips.com/topic/695685-gtx-1070-fps-help/#findComment-8920887
