I've made a recent topic comparing 4 different cases and I ended up going with the Tecware Alpha. Now, I've found its little brother, the Tecware F3 which is slightly smaller but has the same black + white theme I'm going for. I've listed the specifications as well as links to their official product pages and reviews.
Tecware Alpha (WHITE + BLACK) Official Product Page Tecware Alpha Review
1.Price on my local online store: 198 MYR
2. I/O:
- Super speed USB 3.0 x2
- HD Audio + USB 2.0 x2
- I/O covers
3. BAYS
- Removable 2x 5.25" bay
- 2x Tool free 3.5” / 2.5" bays
- 3x SSD support
4. FANS (3x 120mm White Non-LED fans included)
- 2x 140mm or 120mm White bladed fan (2x 120mm White non-LED fans included)
- 2x 120mm (Top)
- 120mm White bladed fan (1x 120mm White non-LED fans included)
5. SUPPORT AND CLEARANCE
- up to Standard ATX Motherboard support
- Top 240mm Radiator support
- Front 280mm Radiator support
- 415mm Maximum GPU card length
- 160mm Maximum CPU cooler height
- 21mm Cable Management support
6. OTHERS
- Bottom mount PSU with Washable anti-dust air filter
- Top Magnetic dust filter
- Large & Clear side panel window
- Black Interior Chassis
- Bottom chamber cover for PSU and HDD
- Cable management with Black case wires
7. SIZE
- Structure size : L 486mm x W 200mm x H 502mm
Tecware F3 (WHITE + BLACK) (Also manufactured as DIYPC-F2 or CiT F2 in other regions.) Official Product Page Tecware F3 Review
1. Price on my local online store: 120 MYR
2. I/O
- HD Audio + USB x2
3. BAYS
- 2x 3.5” bays
- 3x SSD support
4. FANS (2x 120mm White LED Fans included, NOT Blue LED as in the review)
- 2x Front 120mm fan (1x 120mm White LED fans included)
- Rear 120mm fan (Optional)
- Top 120mm LED fan (1x 120mm White LED fans included)
- Supports Standard iTX / mATX motherboards
- 315mm Maximum GPU card length
- 240mm Front interior radiator support
6. OTHERS
- Clear Side panel window
7. SIZE
- Structure size : L 335mm x W 185mm x H 355mm
So, which one is the best in terms of value for price, aesthetics, specifications, upgradability and cable management? Thanks! :)
My Daily Driver:
Acer Predator Helios 300
»« Intel Core i5-8300H »« 16GB DDR4 RAM »« NVIDIA GeForce GTX 1060 6 GB »« Silicon Power A60 512 GB M.2 SSD »«
Toshiba PC L200 1 TB HDD »« Microsoft Windows 10 Home »«
https://linustechtips.com/topic/695672-tecware-f3-case-vs-tecware-alpha-case/
F3 seems like more of a value entry-level case while seems like a decent NZXT S340 competitor. if you got the extra money than i'd pick the alpha but if you don't the F3 is a good choice.
