7 minutes ago, safarihunter said:
So I just built my first PC and here is my list: https://pcpartpicker.com/list/wZCMFd The CPU light is on and i think it is because of the water cooler fans not being pliugged in the right places. Your help is much appreciated.
What CPU light?
https://linustechtips.com/topic/695535-cpu-light-on/#findComment-8909968
2 minutes ago, corrado33 said:
What CPU light?
There's typically now a debugging LED for components that light up if theres a possible issue.
Check the CPU power, it's a 4 or 8 pin connector on the motherboard.
Desktop i7-5820K @ 4.7GHz | ASUS Rampage V Edition 10 | 64GB DDR4 Corsair LPX | Titan X (1st Gen) | 256GB 950 Pro SSD + 8TB WD Red HDD | Corsair AX860i | Lian-Li PC-O8 | macOS Sierra + Win10
Audio HD800 + Magni2/Modi2 | Keyboard WhiteFox/ErgoDox | Mouse G502 | HMD HTC Vive
Things I know about: Computer Building, Software Development, Headphones, Mechanical Keyboards, Cosplay, ?
https://linustechtips.com/topic/695535-cpu-light-on/#findComment-8909982
3 minutes ago, safarihunter said:
The CPU led
that motherboard also has a little Dr.debug screen on the bottom. can you see what code it's displaying?
https://linustechtips.com/topic/695535-cpu-light-on/#findComment-8909995
Its a 8 pin and I checked it and I still get the CPU led on
https://linustechtips.com/topic/695535-cpu-light-on/#findComment-8910006
Just now, safarihunter said:
There is no Dr.Debug on the asus z170-a
woops, was thinking about the deluxe.
my bad.
https://linustechtips.com/topic/695535-cpu-light-on/#findComment-8910017
Where on the motherboard am I suppose to plug the CPU fans in? Its the NZXT Kracken z61 water cooler
Check your manual, it should say there ;)
[GUIDE] LGA 771 Mod for Dell Vostro 220 [GUIDE] LGA 775 BSEL Mod [BUILD] The Mighty Radeon-Powered Dell [VIDEO] Evolution of Intel CPUs
Can you game on an 8-year-old i7? Is the 4-year-old GTX 660 still relevant? Upgrading the HP Pro 3500
Main Rig:
CPU Intel Core i7 4930k @ 4.3GHz | Motherboard ASUS P9X79 Deluxe | RAM Hynix 32GB (8x4GB) 2133MHz CL11 | GPU Gigabyte GTX 980Ti G1 Gaming | Case NZXT Phantom 410 | Storage Samsung 850EVO 500GB, Seagate Barracuda 2TB | PSU Cooler Master G650M (650W) | Monitors x1 Dell U2515H, x2 Dell 1907FP | Cooling Noctua NH-D14 w. x2 NF-F12 iPPC-2000 PWM | Keyboard Logitech G610 ORION BROWN | Mouse Logitech Performance MX | OS Microsoft Windows 10 Pro x64
https://linustechtips.com/topic/695535-cpu-light-on/#findComment-8910031
Well, a CPU fan wouldn't prevent POST. It would either immediately shut down or ask you in the BIOS to check the CPU Fan. If the 8pin and 24pin are all snug, make sure the CPU is oriented properly. The problem is possibly elsewhere.
https://linustechtips.com/topic/695535-cpu-light-on/#findComment-8910039
I checked the CPU orientation and its good but i have no display on the monitor when I start up so im guessing that it is something like the computer isn't starting up because the CPU fans aren't being recognized in the right slots. The case fans do spin and the CPU cooler and fans are working but its just not giving display
https://linustechtips.com/topic/695535-cpu-light-on/#findComment-8910061
Does your GPU have power? Does the integrated GPU show anything?
https://linustechtips.com/topic/695535-cpu-light-on/#findComment-8910071
When i had my GPU installed it had power but I then took it out since i thought that the GPU and integrated graphics might be having issues but the same problem remains and I am getting no display
https://linustechtips.com/topic/695535-cpu-light-on/#findComment-8910082
Things get a lot more complicated now. I'd check:
- Standoffs aren't shorting anything on the other side. (Test the motherboard outside the case)
- Various RAM configurations. (One at a time)
- Use only Minimal Viable devices. (CPU/RAM only, video out, and a keyboard.)
https://linustechtips.com/topic/695535-cpu-light-on/#findComment-8910135
How do i test it outside of the case withught a risk of static electricity
https://linustechtips.com/topic/695535-cpu-light-on/#findComment-8910179
Put it on the motherboard box. Don't wear a fleece sweater. Touch something metal if you're worried. It's not that big of a risk.
https://linustechtips.com/topic/695535-cpu-light-on/#findComment-8910253
Ok thanks, so i just figured out the right place for the water cooler fans and still the light so i now know it has nothing to do with the water cooler
https://linustechtips.com/topic/695535-cpu-light-on/#findComment-8910295
