CPU cooler after installation
Go to solution Solved by SLAYR,
Yes, just don't try turning it on without a cooler.
Can I build my PC and later on install the cooler cuz I have a corsair 400c and it has an opening to the back of the Mobo...I don't have the cooler right now.
I'll be putting an h100i v2 later
My PC is a fast boyo:
6700K - 32GB - 1080 - 256GB EVO
^^You don't need more info than this right?^^
https://linustechtips.com/topic/695527-cpu-cooler-after-installation/
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
If you have a stock cooler you can assemble it and use it till you get your h100i. If not, assemble minus the cooler and DO NOT TURN ON.
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
well depends if the cooler has a backplate or not, because if it has one you will need to take the motherboard out to install the cooler
Builds:
The 400c has a cutout at the back which should be enough tbh so bo need to take the mobo out. Should be perfectly fine ?
Main system:
i7 6700k @4.8ghz 1.45v
ROG Maximus Hero VIII
Gigabyte G1 980ti Sli @1500 ghz
Samsung 950 pro 512gb
16gb G.Skill Ripjawz V @3400mhz
Corsair H115i 280mm AIO
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Intel i3 6100 @4.6ghz 1.52v
Asrock B150M Pro4/Hyper
Intel 750 series 400gb
Radeon Rx 470 XFX
Thermaltake Water 3.0 360mm AIO
inWin 303 case
AMD Phenom II x4 940 @3.9ghz 1.65v
Gigabyte 780g mobo
Corsair H100 240mm AIO
Corsair Dominiator 8gb DDR2 @1066
Evga GTX 750ti FTW @1450mhz
Thermaltake Matrix case (modded)
"The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage"
then there will be no problem :)
Builds:
37 minutes ago, SLAYR said:
Unless you stick a small frying pan on it and fry up an egg
Sorry it's not an AMD cpu
