Your temps are low because your fans are probably spinning faster than need be.  Go into the bios and look at what the fan curves are.  They are probably set to go faster than needed.
i5 12600k | ASRock Z690M-ITX 32GB Corsair Vengeance LPX DDR4 3200MHz | EVGA 2080 Super Black | Samsung 970 EVO Plus 500GB + 980 1TB | Corsair RMx 650W | Thermaltake Tower 100 White
https://linustechtips.com/topic/694808-loud-fans/#findComment-8903436
O, those are my CPU temp but is there temp for GPU?
https://linustechtips.com/topic/694808-loud-fans/#findComment-8903446
It's fine. They're loud because they're spinning faster. They're reacting to the added load as they should. There'd be a potential problem if the sound was different instead of just louder. Like grinding or rattling.
BTW, there's more to temps that you can easily spot with basic programs. For instance, the memory on your GPU has no temperature sensors but they still need to be cooled.
https://linustechtips.com/topic/694808-loud-fans/#findComment-8903458
Your GPU temp would be displayed by a program on the desktop not in the bios.  Look up the software for whatever card you have, Asus, EVGA etc etc and download that and it will allow you to control the GPU fan speed.  Or you could download CAM from NZXT which takes care of the CPU and GPU fan speed and gives you a nice display of all the stats from you PC (I highly recommend it).  You can see CPU, GPU and RAM speed as well as voltages, internet speed, frequencies etc etc.  You can also set custom fan speed profiles for your GPU.
All the stats from my PC as an example:
https://linustechtips.com/topic/694808-loud-fans/#findComment-8903477
You say your fans are loud? Kappa I used to have 3 Vardar FF5 at 3000 RPM pushing 540 CFM of intake :)
CPU: Intel Core i9-10900K  MOBO: ROG MAXIMUS XII FORMULA GPU: 2080ti Hall of Fame 10th anniversary limited edition  PSU: Asus ROG THOR 1200W  COOLER: Optimus foundation black acetal RADS: 3x EKWB CoolStream PE 360  LOOP: EKWB torque HDC fittings / EKWB ZMT 15,9/9,5mm / EKWB CryoFuel Clear MONITOR: Acer predator X34
https://linustechtips.com/topic/694808-loud-fans/#findComment-8903492
Ok, im downloading cam right now.
Just making sure, is it this website?
https://camwebapp.com/
https://linustechtips.com/topic/694808-loud-fans/#findComment-8903521
Yup!  It also links with whatever NZXT products you have like I have an NZXT Hue+ so I can control my rgb leds from CAM.
https://linustechtips.com/topic/694808-loud-fans/#findComment-8903535
Ok, so I played overwatch for 10 minutes and got this results, it pretty much capped at those temperatures.
https://linustechtips.com/topic/694808-loud-fans/#findComment-8903676
I would definitely change up the fan curve for your GPU because my card (EVGA 1070 SC) idles at a lower speed than yours and those fan speeds seem crazy high.  I have my speed set to go up basically one percent every degree so at 60 C it'll only be at 60% fan speed and it looks like yours are going up to 100%.  Everything else looks fine though.
https://linustechtips.com/topic/694808-loud-fans/#findComment-8903712
How do I change the speed?
https://linustechtips.com/topic/694808-loud-fans/#findComment-8903732
Go out of full screen view so it's just a little window floating around and in the top left there will be different sections like "Dashboard" "Build" "Games" and "Tuning" go to Tuning and in the little area where you see the fan curve just click "Change Mode" and set up a custom curve, I have mine going in a pretty chill line just plus ten degrees by plus ten percent so when the card is at 60 C the fans will be at 60% etc. then name the profile if you want and hit save changes.  And check "Apply tuning when CAM starts" if it's not already.
https://linustechtips.com/topic/694808-loud-fans/#findComment-8903756
Do you mind sending a picture please, I don't wanna ruin this lol
thanks
https://linustechtips.com/topic/694808-loud-fans/#findComment-8903772
thanks
No problem.
Just click "Change Mode" under "GPU 1 Fan Profile" and make your curve how you want and then click "Save Changes" and make sure "Apply Tuning When CAM Starts" is checked.
https://linustechtips.com/topic/694808-loud-fans/#findComment-8903793
4 minutes ago, Gamessys said:
No problem.
So 5% for every 5 Celsius and to what temperature do i spike it up?
https://linustechtips.com/topic/694808-loud-fans/#findComment-8903834
I have mine set to 80% at 80C and then from 80C - 90C I spike it to 100% speed just in case but my card barely even reaches 70C.
https://linustechtips.com/topic/694808-loud-fans/#findComment-8903867
Just to make sure, I got: 40% at 20°C , 40% at 30°C , 45% at 40°C , 50% at 50 °C , 50% at 60°C , 55% at 70°C , and 80% at 80°C
https://linustechtips.com/topic/694808-loud-fans/#findComment-8903940
I would probably have 60% at 60C and 65 or 70% at 70C just to not have a nasty 25% spike from 70-80C and after that I would have it pinned at 100% because anything over 80C and it's getting a little hot for my taste.  I like having a nice smooth curve because if you have spikes like 55 to 80% speed from 70-80C if your card does go that high then it will be audibly noticeable.
https://linustechtips.com/topic/694808-loud-fans/#findComment-8903974
Ok, so i decided to change the temps to 40% from 20C-40C, from there its 50-50, 60-60 and so on, is that fine?
https://linustechtips.com/topic/694808-loud-fans/#findComment-8904026
Yeah that'll give you a nice solid smooth curve to handle any temps.  I would go test it now and see how it handles.
https://linustechtips.com/topic/694808-loud-fans/#findComment-8904038
Hmm...well when you're gaming what does the fan speed go up to? When you're in a game Alt-Tab and check the speed and stuff of the card in the dashboard.  And what are the temps?  Also is your card a reference card or a custom one like Asus, EVGA etc?
https://linustechtips.com/topic/694808-loud-fans/#findComment-8904076
Ok, Im pretty sure it was higher than before but AS SOON AS I GOT TO THE LOADING SCREEN FOR OVERWATCH FOR LIKE 2 minutes, I said this is enough.Screenshot (25).png
https://linustechtips.com/topic/694808-loud-fans/#findComment-8904110
My card is powercolor
https://linustechtips.com/topic/694808-loud-fans/#findComment-8904116
