hi guys i have 7970 and i want watercool it
now i have this water block
Fitting thread: G1/4"
Supported tube: 9.5 mm(ID) x 12.7 mm(OD) PU tube, or 8 mm(ID) x 12 mm(OD) silicon tube
now i need: pump, radiator (120), tubes and reserve.
Someone can help me? i'm beginners.
i don't know anything about fitting:/
https://linustechtips.com/topic/694742-only-gpu-water-cooling/
dont you have to cool other components on the card, besides the gpu?Image result for gpu water block
Favorite Threads: PSU Tier List
My Stuff n' Things
The Beast (My Rig)   |CPU: AMD Ryzen 7 7800X3D|  |Cooling: Noctus NHU12S Redux, 6x 120mm Noctua Redux|  |Motherboard:  Asus TUF B650-E WiFi|  |RAM: 4x8gb 6000 Corsair VENGEANCE RGB|  |Graphics Card: EVGA(RIP) GeForce RTX 3070TI FTW3|  |Power Supply: EVGA GT 850W|  |Case: Corsair 4000D Airflow Mid Tower Case(Black)|  |SSD: 1Tb SK Hynix Platinum P41 NVMe, 2Tb Inland Prime NVMe, 500gb Inland 2.5", 4tb WD Blue HDD|  |Monitor: MSI Optix MPG341QR 34" Ultrawide|  |Keyboard: Logitech G815|  |Mouse: Logitech G305|  |Audio Interface: FiiO K7 DAC/Amp|  |Headphones: Sennheiser HD6XX |Webcam: Logitech C920, Logitech C270|
My Network Rack  |Switch: Cisco Dell PowerConnect 5548P|  |Router: Unifi USG|  |Rack: 12U|  |Server: HP Z420|  |Services: Proxmox PVE, Wireguard, Pihole, NVR, NAS|
https://linustechtips.com/topic/694742-only-gpu-water-cooling/#findComment-8902682
If you are going for a GPU only loop you may want to consider lookingat AIO loops the cost associated with just watercooling a GPU wouldn't be worth the time unless you were doing both a CPU and GPU or were incorporating the CPU into the loop later on. Also you would be best off getting a full cover waterblock if you were going to do custom watercooling.
https://linustechtips.com/topic/694742-only-gpu-water-cooling/#findComment-8902699
Indeed.
You need to look for something to cool your VRAM and VRM as well.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/694742-only-gpu-water-cooling/#findComment-8902748
this gpu have just now this cooler, and the temp is fine lik 58° on load
https://linustechtips.com/topic/694742-only-gpu-water-cooling/#findComment-8902768
http://www.performance-pcs.com/alphacool-nexxxos-atxp-ati-7970-50-series-polished-stainless-steel-black.html
http://www.performance-pcs.com/ek-xlc-predator-240-all-in-one-liquid-cooler.html
Probably the easiest and nearly the cheapest if not the cheapest solution.
EK Predator AIO and Alphacool full waterblock.
~250 USD
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
https://linustechtips.com/topic/694742-only-gpu-water-cooling/#findComment-8902777
~250 USD
8 minutes ago, jj9987 said:
Indeed.
https://linustechtips.com/topic/694742-only-gpu-water-cooling/#findComment-8902786
12 minutes ago, wlaro said:
https://www.ekwb.com/shop/ek-vga-supremacy-nickel - GPU ONLY BLOCK, FITS 7970
http://www.performance-pcs.com/ek-xlc-predator-240-all-in-one-liquid-cooler.html COMPATIBLE AIO
Just take the block off the predator and connect the tubes to the block you have.
~210 USD
https://linustechtips.com/topic/694742-only-gpu-water-cooling/#findComment-8902828
1 minute ago, TidaLWaveZ said:
so if i buy this https://www.ekwb.com/shop/ek-vga-supremacy-nickel from
what pump tubes and reserve i have to buy
p.s. (in the future i will buy cpu waterblock)
https://linustechtips.com/topic/694742-only-gpu-water-cooling/#findComment-8902841
None.
It's an AIO, you literally just connect the tubes to your current GPU block.  The pump/res is built into the top of the radiator.
(make sure the AIO is drained before the process of course)
https://linustechtips.com/topic/694742-only-gpu-water-cooling/#findComment-8902850
3 minutes ago, wlaro said:
yes i see it but i want costum watercooling
I was just offering the most simple setup
If you wan't a fully custom loop know that the process will be more complicated.  Here are EK kits that are good for beginners. I'm not really trying to promote EK, but it's all that I have experience with.
https://www.ekwb.com/shop/kits
https://linustechtips.com/topic/694742-only-gpu-water-cooling/#findComment-8902880
