New pc build help
Go to solution Solved by NTDaws,
4 minutes ago, n00bmlg said:
Yeah, but he could spend $30-$40 more and get way better performance
And he is only playing Minecraft and some COD games, you can crank does easily on a GTX 980, so most likely you can put those on very high on a 1050ti
Hey guys so I'm back in pc build!ding and I want to build this PC here but I need some help on if it's a good pc. Also how many fps can it get n C's go Minecraft and some cod games. Also what monitor should I get?
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($190.89 @ OutletPC)
Motherboard: MSI Z170-A PRO ATX LGA1151 Motherboard  ($89.99 @ Newegg)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2133 Memory  ($77.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.89 @ OutletPC)
Video Card: MSI GeForce GTX 1050 Ti 4GB Video Card  ($139.99 @ B&H)
Case: Corsair 200R ATX Mid Tower Case  ($54.99 @ Newegg)
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply  ($46.99 @ OutletPC)
Total: $649.73
Generated by PCPartPicker 2016-11-21 14:43 EST-0500
https://linustechtips.com/topic/694303-new-pc-build-help/
It should be able to break 100+  frames in both. I don't know much about those games though. A couple of suggestions:
1. Get a h110, h170, or b150 board instead (Here is a list of all of them, so you can decide which one you want: http://pcpartpicker.com/products/motherboard/overall-list/#s=30&c=112,113,111&f=2&sort=a8&page=1)
2. You don't need 16gb. of RAM. While I would recommend it, for this type of build I would recommend getting 8gb. and spending the rest of the money on an SSD or something. You can always upgrade to 16gb. later.
https://linustechtips.com/topic/694303-new-pc-build-help/#findComment-8898297
5 minutes ago, riley mclinn said:
Thanks!
Also, if I were you I would switch to http://www.corsair.com/en/cx-series-cx430m-modular-atx-power-supply-430-watt-80-plus-bronze-certified-modular-psu if I were you because cable management will be a pain if you don't use modular or at least semi modular.
lttstore.com
https://linustechtips.com/topic/694303-new-pc-build-help/#findComment-8898401
8 minutes ago, Dawson Wehage said:
Yeah then you'll be fine. Don't buy the rx480, a 1050 ti performs just liek a gtx 960 4gb so you should be getting 60fps in games such as GTA V for example.
I said 470, they're only $30-$40 more than the 1050 ti and you get almost double the performance
https://linustechtips.com/topic/694303-new-pc-build-help/#findComment-8898406
Yeah but if he doesn't need it. Don't make someone spend more money if they don't need too. The plan is always cheap as possible.
lttstore.com
https://linustechtips.com/topic/694303-new-pc-build-help/#findComment-8898427
It would be worth it in the long rum, and besides, with the 1050 ti he wouldn't get 1080p 60FPS Ultra in every game, with the 470 he would
https://linustechtips.com/topic/694303-new-pc-build-help/#findComment-8898436
This card uses less power at 75watts. And I said it can in most games. Not all but most. Especially for some good old 1080p.
lttstore.com
https://linustechtips.com/topic/694303-new-pc-build-help/#findComment-8898444
And eventually he probably will buy a 1070, but right now the 1050ti is a great card for the price.
lttstore.com
https://linustechtips.com/topic/694303-new-pc-build-help/#findComment-8898458
lttstore.com
https://linustechtips.com/topic/694303-new-pc-build-help/#findComment-8898508
