Start off by stating what purposes you are trying to fill.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/694276-workstation-build/#findComment-8897878
3 minutes ago, Fabiothrman said:
I am trying to build a pc that can render, edit, and do 3d rendering. more of a editing workstation.
Than id get.
i7 6800K
Asus X99 Deluxe
GTX 1070
Whatever else you need, but for those jobs, these parts will be best
Roses are red
My name is Roy
We caught the alligator that ate the De Luca boy
https://linustechtips.com/topic/694276-workstation-build/#findComment-8897896
This would be much faster
PCPartPicker part list: http://pcpartpicker.com/list/N9x2bj
Price breakdown by merchant: http://pcpartpicker.com/list/N9x2bj/by_merchant/
CPU: Intel Core i7-6800K 3.4GHz 6-Core Processor  ($379.99 @ Newegg)
CPU Cooler: Cooler Master Hyper T4 70.0 CFM Rifle Bearing CPU Cooler  ($12.89 @ OutletPC)
Motherboard: ASRock X99 Extreme4 ATX LGA2011-3 Motherboard  ($139.98 @ Newegg)
Memory: ADATA XPG Z1 16GB (2 x 8GB) DDR4-2400 Memory  ($67.40 @ Newegg)
Storage: Crucial MX300 275GB M.2-2280 Solid State Drive  ($66.50 @ Newegg)
Video Card: Zotac GeForce GTX 1050 2GB Mini Video Card  ($109.99 @ B&H)
Case: Corsair 200R ATX Mid Tower Case  ($44.99 @ Newegg)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($41.89 @ OutletPC)
Operating System: Microsoft Windows 10 Pro OEM 64-bit  ($98.99 @ My Choice Software)
Total: $962.62
Generated by PCPartPicker 2016-11-21 13:52 EST-0500
https://linustechtips.com/topic/694276-workstation-build/#findComment-8897899
Get a 6800K (don't overclock) and X99. @Electronics Wizardy has a good build but I would change to a 1050Ti.
https://linustechtips.com/topic/694276-workstation-build/#findComment-8897909
Total: $962.62
That's incredible!!! all under 1k
https://linustechtips.com/topic/694276-workstation-build/#findComment-8897917
if you are going for editing i would say go for a 6700k. if you are using adobe premiere, it has a hard time taking advantage of more than 4 cores and you can use the rest of that on storage. a big ssd makes a big difference for editing. check out the new 960 evo from samsung. 16gb of ram should be just fine.
https://linustechtips.com/topic/694276-workstation-build/#findComment-8897931
You can adapt an NZXT S340 to become a very good case for an EEB motherboard. http://www.overclock.net/t/1539027/nzxt-s340-is-perfect-for-eeb-e-atx-server-boards
https://pcpartpicker.com/b/fYjcCJ
Alas, even then I was only able to put the build down to $1200, but you're likely to find a cheaper motherboard somewhere.
CPU: Intel Xeon E5-2670 2.6GHz 8-Core Processor  ($100.00)
CPU Cooler: RAIJINTEK AIDOS BLACK 48.6 CFM Sleeve Bearing CPU Cooler  ($19.95 @ OutletPC)
Motherboard: ASRock EP2C602-4L/D16 SSI EEB Dual-CPU LGA2011 Motherboard  ($315.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR3-1866 Memory  ($89.89 @ OutletPC)
Storage: PNY CS1311 120GB 2.5" Solid State Drive  ($39.99 @ Best Buy)
Storage: Toshiba 2TB 3.5" 7200RPM Internal Hard Drive  ($64.95 @ Amazon)
Case: NZXT S340 (White) ATX Mid Tower Case  ($66.99 @ SuperBiiz)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($78.99 @ SuperBiiz)
Case Fan: be quiet! SHADOW WINGS 44.1 CFM  80mm Fan  ($6.73 @ Amazon)
Monitor: Asus VX228H 21.5" 60Hz Monitor  ($119.99 @ Newegg)
Total: $1232.40
Generated by PCPartPicker 2016-11-21 13:55 EST-0500
A high-power workstation with an EVGA 500B? What are you crazy? And no hard drive.
Motherboard: ASRock X99 Extreme4 ATX LGA2011-3 Motherboard  ($179.98 @ Newegg)
Memory: Mushkin Blackline 16GB (2 x 8GB) DDR4-2400 Memory  ($72.99 @ Newegg)
Storage: Hitachi Ultrastar 7K3000 2TB 3.5" 7200RPM Internal Hard Drive  ($49.00 @ Amazon)
Case: Fractal Design Core 2300 ATX Mid Tower Case  ($39.99 @ SuperBiiz)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($57.99 @ NCIX US)
Total: $1075.37
Generated by PCPartPicker 2016-11-21 14:03 EST-0500
If I were you, I would look up whether your programs can use 32 threads, because if it can, the dual E5-2670s will wipe the floor with a 6800K.
6 minutes ago, UberGamerKing said:
That CPU cooler wont be enough
Get a Hyper 212 EVO, the T4 is too small
It is enough for non-OC 140W CPUs. But the 212 EVO isn't much better, for OC better grab something beefy like a Thermalright Macho Direct.
http://pcpartpicker.com/product/TsL7YJ/thermalright-cpu-cooler-machodirect
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/694276-workstation-build/#findComment-8897936
It will be enough. You don't want to overclock a system that is used for editing if it's the first (or even second) time.
https://linustechtips.com/topic/694276-workstation-build/#findComment-8897942
Oh yeah, i was getting the T4 confused for the T3
Roses are red
My name is Roy
https://linustechtips.com/topic/694276-workstation-build/#findComment-8897954
Total: $1232.40
Total: $1075.37
So I better CPU and CPU Cooler would be the way to go
https://linustechtips.com/topic/694276-workstation-build/#findComment-8897971
It depends on how many threads your programs can utilize. You'll have to do that research.
Computer Specs:
https://linustechtips.com/topic/694276-workstation-build/#findComment-8898003
