If someone can help me
Hey LinusCommunity I want to know if the Gigabyte GeForce GTX 1060 WindForce OC 6G supports VGA adapter???
I have a old FHD monitor with VGA connection and I want to know if will work with this video card.
It work on HDMI > VGA??
I really want to buy this new video card but I have fears about this situation.
http://www.gigabyte.com.ro/products/product-page.aspx?pid=5978#sp
https://linustechtips.com/topic/694200-if-someone-can-help-me/
2 minutes ago, Katsunaka said:
Why not just do DVI to VGA?
1 minute ago, TurkeyClub said:
Because this card doesn't support analog ....
OP, if you want to use VGA you will need an active adapter, not just a cable.
https://linustechtips.com/topic/694200-if-someone-can-help-me/#findComment-8897120
Also, what monitor are you using? Is it even worth getting a card that is way overkill for an old monitor?
https://linustechtips.com/topic/694200-if-someone-can-help-me/#findComment-8897121
Not necessarily have to be on HDMI > VGA.
I want to know if will supports VGA adapter and if can be a cheap solution for this it will be wonderful. But I need to be 100% it will work.
I don't want to buy a card which don't work on my monitor.
I no have money for upgrade monitor now, in the future will take a new monitor.
https://linustechtips.com/topic/694200-if-someone-can-help-me/#findComment-8897194
I don't want to buy a card with don't work on my monitor.
Just get a DisplayPort or hdmi to vga mate
https://linustechtips.com/topic/694200-if-someone-can-help-me/#findComment-8897203
Why, the hell would anyone still use vga?!?!? seriously how the fuck is it still alive??!?!!?! dvi should have replaced it right now, and you want to use a gtx 1070 with the monstrosity known as vga?!!?!?!? NO ONE SHOULD USE VGA ANYMORE IT SHOULD DIE A PAINFUL DEATH.
https://linustechtips.com/topic/694200-if-someone-can-help-me/#findComment-8897286
It will work on Gigabyte GeForce GTX 1060 WindForce OC 6G???
I hear these new video card on NVidia series do not support VGA adapter but I don't sure if is fake or true, that's why I ask you guys.
@alizaidi2000
I can"t upgrade my monitor on 2k or 4k with my current video card.
I need first buy the video card and then I will upgrade my monitor.
As you can see I'm not rich to buy both.
https://linustechtips.com/topic/694200-if-someone-can-help-me/#findComment-8897310
"How about a DisplayPort to vga?
It should work."
Can you tell more about this active adapter??? What is the difference??
I will go with DisplayPort then if will work on this new card.
https://linustechtips.com/topic/694200-if-someone-can-help-me/#findComment-8897447
Go with a DisplayPort to VGA adapter, it will be cheaper than an active adapter.
https://linustechtips.com/topic/694200-if-someone-can-help-me/#findComment-8897481
@alizaidi2000
The new NVIDIA cards do not support passive DVI-I to VGA adapters because those require a special type of DVI port which the new NVIDIA cards do not have. HDMI and DisplayPort to VGA active adapters will still work. Active adapters don't require any "support" from the graphics card. Generally DisplayPort to VGA is recommended if you don't have a DVI-I port.
https://linustechtips.com/topic/694200-if-someone-can-help-me/#findComment-8898064
Yes, so with a DisplayPort to vga or hdmi to vga, it will work
https://linustechtips.com/topic/694200-if-someone-can-help-me/#findComment-8898100
Thanks very much for all who answer my question you help me a lot. Best community?
https://linustechtips.com/topic/694200-if-someone-can-help-me/#findComment-8898303
