Just now, getfishslapped said:
Looking for a good wifi adapter for my pc, i'm currently using a netgear wna3100v3 and its pretty garbage tbh. I can't play esea on csgo without my ping spiking up randomly every 5 minutes, it goes from 20 ping to 150 out of no where. Please help thanks.
they pretty much all suck get a powerline ethernet kit.
6600K - ASUS Z270i Gaming ITX - 8GB Corsair  Vengence LPX DDR4 2400MHZ - EVGA 1070SC - 120GB HyperX Savage SSD - CX430 PSU:|
PSU tier list-
https://linustechtips.com/topic/694173-best-wifi-adapters/#findComment-8896791
What @Matt_98 said. Depending on how far you are from your router, and how many other devices are connected to the same network, wifi may never work no matter how good an adapter you get. Hardline is always the way to go for gaming.
When in doubt, re-format.
https://linustechtips.com/topic/694173-best-wifi-adapters/#findComment-8896801
Modern day adapters arent that bad. My laptop for example performs nearly identically on gigabit ethernet and wifi.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/694173-best-wifi-adapters/#findComment-8896811
1 minute ago, getfishslapped said:
I try to use Ethernet for my pc but it doesn't recognize the Ethernet cable. I have no idea if its a motherboard problem or just the cable.
Update / install drivers.
https://linustechtips.com/topic/694173-best-wifi-adapters/#findComment-8896814
Buy a new cable, if the doesnt work maybe buy an ethernet adapter so you dont have to use the one built into your motherboard
https://linustechtips.com/topic/694173-best-wifi-adapters/#findComment-8896815
Definitely try to troubleshoot your wired problems before trying to go with a wifi solution.
The new 8011AC with mu-mimo is ok for gaming, but that requires a $150-250 router and another $50ish on the adapter at least. Without the mumimo features, as soon as other clients start using the wifi as well, your ping will go to shit, especially if someone is streaming over the wifis.
https://linustechtips.com/topic/694173-best-wifi-adapters/#findComment-8896829
If it's not possible for you to use Ethernet which would be by far the best option I would recommend getting an tp-link archer T9e which is what I have. You are always going to get slight spikes if you are on a 2.4 Ghz network. That's why I would only recommend using this adapter for gaming over a 5Ghz network because it is very stable. So as long as you have a decent dual band router you will be fine.
Unsure what power supply to pick?
Check out my HTPC build.
Quote me/others so we can help you
Comic sans is the best font
https://linustechtips.com/topic/694173-best-wifi-adapters/#findComment-8896840
I'll try an Ethernet adapter because my drivers are updated and still doesn't work. Is this one good? http://www.newegg.com/Product/Product.aspx?Item=N82E16833166088&cm_re=Ethernet_adapter-_-33-166-088-_-Product
https://linustechtips.com/topic/694173-best-wifi-adapters/#findComment-8896850
