Just now, Electronics Wizardy said:
Id use the stock cooler. Its cool and quiet with the low power cpu's intel is making.
Don't get a 300 dollar 950. For that buget get a 1060 or a 1070.
Got the 950 for $100 from a friend who got it and never used it.
gonna upgrade to a 1060 after a while
https://linustechtips.com/topic/693417-my-first-build/#findComment-8889862
for the same price you can get a 6600k use Triple15 for the code.
CPU-i7 6700k O.C. 4.6Ghz-Motherboard-Asus z170-a-RAM-24gb DDR4-GPU-EVGA GTX 1080 FE-Case-Corsair 400c (white)-Storage-HDD: 2xWD Blue 1TB SSD: PNY SSDSC120GLC709B121-510 120GB-PSU-1000 watt coolermax-Display-ASUS VG248QE Black 24" 1080p 144 Hz -Cooling-Corsair H115i-Keyboard-G.Skill KM780 Cherry MX blues (Red backlight)-Mouse-Logitech G602-Sound-Logitech 5.1 z506
Need a budget headphone for under 100$? Sennheiser HD 558 Headphones
Got a Skylake CPU (k) Here is a guide to OC it!
https://linustechtips.com/topic/693417-my-first-build/#findComment-8890006
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.99 @ Newegg)
Motherboard: MSI Z170-A PRO ATX LGA1151 Motherboard  ($89.99 @ Newegg)
Memory: GeIL EVO POTENZA 16GB (2 x 8GB) DDR4-2133 Memory  ($67.99 @ Newegg)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($164.99 @ B&H)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.89 @ OutletPC)
Video Card: EVGA GeForce GTX 950 2GB Superclocked+ ACX 2.0 Video Card  (Purchased For $0.00)
Case: Corsair 200R ATX Mid Tower Case  ($54.99 @ Newegg)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($74.99 @ Jet)
Case Fan: Corsair Air Series SP120 High Performance Edition (2-Pack) 62.7 CFM  120mm Fans  ($24.88 @ OutletPC)
Keyboard: Logitech G610 Wired Gaming Keyboard  ($89.99 @ Best Buy)
Mouse: Logitech G502 Wired Optical Mouse  ($57.51 @ Jet)
Other: i5 6600k ($189.00)
Other: Intel SSD 600p Series (256GB, M.2 2280 80mm NVMe PCIe 3.0 x4, 3D1, TLC) Reseller Single Pack ($79.99)
Total: $973.20
Generated by PCPartPicker 2016-11-19 22:16 EST-0500
since you already bought the card. there ya go
https://linustechtips.com/topic/693417-my-first-build/#findComment-8890027
