Cable Management Pointers?
Go to solution Solved by STRMfrmXMN,
The Tesseract has plenty of cable management. I've built in one. Just loop ALL of your PSU cables through the bottom cable thing. They should be tied together taut.
See how the cables leading from the AX1200 go through that grommet there? That's a great starting point.
I built my new PC on Tuesday, and at the time was too excited to pay attention to cable management, so it was atrocious. What you see now is the effort of an hour and a half to get it cleaned up, but I do believe that it could be better, I just don't know how.
I realize the green ties are atrocious, and those will be changed out later. But any other cable-management tips would be welcome.
Thanks.
i5-6600K @ 4.5 GHz |I| Hyper 212 EVO |I| ASUS STRIX Z270E |I| 8 GB DDR4 HyperX FURY
GTX 1060 Windforce OC 6GB @ 2088 MHz
DEEPCOOL TESSERACT WH |I| EVGA 500 W1 80+
1TB 7200rpm HDD |I| 120GB SSD
GN246HL 144Hz 1080p
Corsair K70 LUX RGB |I| Corsair M65 Pro RGB
PCPP: https://ca.pcpartpicker.com/b/DHzYcf
https://linustechtips.com/topic/693389-cable-management-pointers/
oh my god.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
Just now, RGProductions said:
What case are you using?
The Deepcool TESSERACT ATX Mid Tower case.
GN246HL 144Hz 1080p
I think a modular PSU in the future would help a lot, but I couldn't fit it in the budget currently.
GN246HL 144Hz 1080p
1 minute ago, RGProductions said:
Somewhere down the line I'd recommend a Z170 ATX board and a better case.
What case do you recommend? I tried to put most of my budget towards CPU & GPU so I compromised on some of the other parts, but definitely a future case/PSU/mobo upgrade is in order.
GN246HL 144Hz 1080p
Depends, I'd get a new MOBO first though.
M1 MacBook Air 256/8 | iPhone 13 pro
That is very impressive indeed. I shall do that. Also having a modular power supply and those delicious custom cables will be at the top of my priority list. Thanks.
GN246HL 144Hz 1080p
No problem :)
