So here is my part list:
https://www.mindfactory.de/shopping_cart.php/basket_action/load_basket_extern/id/422b53221348c13f194edf85d8b5352bdc8555a202d8dc32b0a
Are the parts compatible?
Should i add/remove something.
This is my entire budget so i can not spend any more :)
https://linustechtips.com/topic/693359-pc-build-for-christmas/
Better quality PSU.
https://linustechtips.com/topic/693359-pc-build-for-christmas/#findComment-8889147
Its good except for the power supply which i would get something modular and preferably 80+ gold.
Unsure what power supply to pick?
Check out my HTPC build.
Quote me/others so we can help you
Comic sans is the best font
https://linustechtips.com/topic/693359-pc-build-for-christmas/#findComment-8889155
Just now, RKRiley said:
Swap the PSU for that and you're good to go. (it is 10 euros more, but it'll be worth it.)
https://linustechtips.com/topic/693359-pc-build-for-christmas/#findComment-8889175
psu should be fine you if its cheaper keep it especially with z170 and with overclocking for both cpu and gpu also leads for more oppurtunities later on
https://linustechtips.com/topic/693359-pc-build-for-christmas/#findComment-8889270
how would it be worth it???? id say not worth it you really spend like nothing more in amount of money for electricity also allows for more opportunities later down the road keep the psu
https://linustechtips.com/topic/693359-pc-build-for-christmas/#findComment-8889274
The psu he's chosen isn't on the PSU tier list, or even on the whitelist, thats why its worth the extra money to buy one thats tier 3.
https://linustechtips.com/topic/693359-pc-build-for-christmas/#findComment-8889285
1 minute ago, RKRiley said:
The psu he's listed on it isn't on the PSU tier list, or even on the whitelist, thats why its worth the extra money to buy one thats tier 3.
its coolermaster personally products from cooler master ive had have no problems but i didnt see that good catch
https://linustechtips.com/topic/693359-pc-build-for-christmas/#findComment-8889295
alright but i would definitely try to find some big deals cyber monday idk if where you are has it
Sadly Cyber Monday or Black Friday are not realy a thing here in Germany .
Only Amazon does it, but i have never seen any good Hardware deals there.
https://linustechtips.com/topic/693359-pc-build-for-christmas/#findComment-8889311
