Depends on the CPU, but probably not.
i5-6600k (4.6) | Dark Rock 3 | MSI GAMING X 1060 6GB | 8GB DDR4 | 120GB SSD & 1TB HDD | Crystal 460x
 | Acer GN246HL 1080p 24" 144hz & Acer G246HL 1080p 24" 60hz |
PSU Tier List | PC Partpickers: US Canada Australia UK
https://linustechtips.com/topic/692737-power-supply/#findComment-8883472
14 minutes ago, jebron_lames10 said:
Can a 250w power supply power a gtx 1050ti ?
The short answer would be "probably".... 1050ti only uses 75W.... the rest of the system would need to consume at least 125W to really stress your PSU at all (assuming it wouldn't be able to actually manage its rated 250W, which it may in fact be able to do). Assuming you have appropriately poweful components in your system, then that is unlikely to happen. But my advice is still the same as the rest of the people in this thread. you should really consider investing in a better PSU
https://linustechtips.com/topic/692737-power-supply/#findComment-8883509
  • 2 weeks later...
I have a i7 4790k and 16gbs of ram, its says 80 plus bronze efficiency on the psu
https://linustechtips.com/topic/692737-power-supply/#findComment-8927266
if you have a 4790k I assume you're going to be overclocking it... when you overclock it, then you're going to definitely exceed your PSU's and even if you don't overclock it, your power draw is going to be cutting it pretty close. You should definitely get a new PSU imo.
https://linustechtips.com/topic/692737-power-supply/#findComment-8927347
I was thinking to buy a new case that has a built-in psu, for how much power should I look for?
https://linustechtips.com/topic/692737-power-supply/#findComment-8927386
the short answer? you should rarely trust a PSU that comes with a case. even moreso when you are considering overclocking. overclocking puts a unique load that can cause cheaper/low quality PSU's to buckle and/or fail under the strain, if nothing else it can cause system instability if your PSU cannot provide a smooth and consistent amount of power. ideally you should buy a case/PSU separately.
as far as how much wattage you need, 400W should be your minimum... but PSU's are very cheap up to 500-550W, so you shouldn't shy away from getting one such unit if it suits your fancy. If you intend to overclock, you should look for a T3 PSU or higher. if you don't, a T5 or higher would be advised, based on this list here:
https://linustechtips.com/topic/692737-power-supply/#findComment-8927408
I will look into it thank you very much on the help☺
https://linustechtips.com/topic/692737-power-supply/#findComment-8927444
