Tecware Alpha Build
So I have finally put together my Photo/Video Editing and Gaming workstation..
At this point I want to add some bling and proper cooling
PC Specs:
Intel i7 6700
ASUS H-170 PRO
8GBx2 Crucial 2133MHz DDR4
Samsung EVO 850 250GB
Toshiba 3TB HDD
Zotac GTX 1070 Mini
Seasonic M12II 520W
Tecware Alpha Mid Tower
The things I want to change:
I currently have the CPU Stock cooler and Stock Case fans
No RGB lighting on any component
Long Term plan:
2 Corsair SP 120 LED Fans in Front (Intake)
2 Corsair SP 120 LED Fans on Top (Intake)
1 Corsair AF 120 LED Fan at the back (Exhaust)
Cryorig M9i CPU Cooler
What do you think?
https://linustechtips.com/topic/692498-tecware-alpha-build/
40 minutes ago, GalacticRuler said:
Would've saved $100 and gotten a Xeon for the CPU, but otherwise it's great.
judging from the case he has, he's from the Philippines. Xeons aren't available here.
Karamo
CPU: AMD Ryzen™ 5 3600 | CPU Cooler: Wraith Stealth | GPU: Gigabgyte AORUS GeForce RTX 2070 Super | Motherboard: MSI B450M Mortar Max | RAM: G.Skill FlareX 2x8GB 3200MHz CL16 | SSD: ADATA XPG SX6000 Pro M.2 256GB | HDD: 1TB 2.5" Western Digital Blue (WD10SPZX) | Case: NZXT H510 | OS: Windows 10 Pro 64-bit |
https://linustechtips.com/topic/692498-tecware-alpha-build/#findComment-8881176
Yup, I'm Filipino based in Singapore.
Got the Tecware alpha as it looks good and has the features I need to keep the system looking clean..
I got the i7 as I didn't purchase the GPU right away and needed a stopgap
https://linustechtips.com/topic/692498-tecware-alpha-build/#findComment-8881238
Pinoy too! Nice build. Good luck mate.
maybe I'll change the hard drive to a Western Digital Blue Caviar.
CPU: Intel Core i5-6600k 4.4GHz | Motherboard: Asus ROG STRIX Z270F Gaming | Cooler: Cryorig H7 | RAM: GSkill Ripjaws V 8GB 2x4 3200 MHz | GPU: MSI GTX 1070 Gaming X | PSU: Seasonic G-550w 80+ Gold Certified, Semi Modular | Storage: 250GB Samsung 850 EVO, 1TB Western Digital Caviar Blue | Case: NZXT S340 Elite (Black/Red) | Monitor: BenQ XL2411 144hz | Keyboard: Corsair STRAFE RGB Cherry MX Silent | Mouse: Corsair M65 Pro RGB
I'd like to make a Chemistry joke, but all the good ones ARGON. *nudgenudge *winkwink
https://linustechtips.com/topic/692498-tecware-alpha-build/#findComment-8881253
On 11/18/2016 at 5:44 PM, LoGiCalDrm said:
You probably won't need extra intake fans on top. They won't do much to overall cooling as CPU cooler is so small already.
I see, I wanted to push the airflow go the back of the CPU for the exhaust. Also looking to go for positive air pressure for less dust inside.
What do you think?
https://linustechtips.com/topic/692498-tecware-alpha-build/#findComment-8895056
What do you think?
For positive pressure 2 in, 1 out is fine. You can further improve that setup by having rear spin at lower speed that two intakes.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/692498-tecware-alpha-build/#findComment-8895370
