Hi, I have a question if any one could repley back to me. I bout a AMD graphics card and I have had it for a mounth and a 1/2 and it is giving me problems. I got it off of Neweeg.com and ther warrantee has run up, but I have registered the card thro AMD.com. I have sent them 2 emails thro there feedback thing for problems and it has been a couple of days and I have got no repley. Now am I wasting my time or will AMD stand by ther product? The card is Flickering and crashes on every game and videos!!! All drivers are up to date.
https://linustechtips.com/topic/692318-problem-with-amd-graphics-card/
Firstly, what card is it?
Secondly, don't bother with email systems. Call AMD up directly, because my Gigabyte MoBo was experiencing issues so I called them up after an email was bounced back to me. Works perfectly now.
2017 Gaming PC
Excellent value machine, keeps me going.
CPU: Intel Core i5-6600K | GPU: Nvidia GeForce GTX 1080 8GB | RAM: 16GB DDR4 | Motherboard: MSI Z170A XPOWER GAMING TITANIUM
PSU: Casecom 600W PSU | Case: Corsair Graphite 230T | SSD: Samsung 850 EVO 250GB | HDD: 3TB WD Blue
Dell XPS 15 9560
Beautiful laptop, in a stunning form factor.
CPU: Intel Core i7-7700HQ | GPU: Intel HD Graphics 630/Nvidia GeForce GTX 1050 (not mobile, full GPU) | RAM: 16GB DDR4 | SSD: 512GB SK Hynix SSD
Display: 4K IPS 100% Adobe RGB Touch Panel | I/O: Two USB 3.0 with PowerShare, HDMI, 3.5mm Headphone Jack, SD Card Slot, and Thunderbolt 3 USB-C
Samsung Galaxy S8 64GB | Samsung Galaxy Tab S2 9.7 32GB
do a fresh install of the drivers with DDU(Display Driver Uninstaller) and then a clean install, might help, might not but do that before you do anything else
Builds:
I have already done a uninstall and reinstall, when I first got the card it was Flickering out the box but was not that bad so didn't think any thing about it but a few day laster I whent to do some gameing and it was Flickering real bad and that's when it startied the crashing?
well if you have done a clean install there probably isnt anything wrong with the drivers and you should call up AMD support and ask about the problem and they will probably know what it is
Builds:
If it was when broke when you got it it was most likely DOA.
Companies don't give month long warranties they are usually at least a year long, and up to 5 years
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
