If I wanted to overclock my gtx 1060, with an i5 6500, what kind of boost can I expect? Like if I was playing games like Crysis 3, CSGO, Overwatch, Infinite Warfare, Minecraft, Block Ops 3, etc. Also, what kind of things should I do to make sure its safe to overclock a graphics card?
My build in fancy text: http://pcpartpicker.com/list/BWGdxY My current build: http://imgur.com/gallery/sOgMR3u
https://linustechtips.com/topic/691444-overclock-gtx-1060-boost/
Why are you asking about your 1060 and 6500 when your other thread is on you only having a low spec laptop?
My 1060 OC'd to 2139mhz at stock voltage, but now it's running underclocked because I have a 1280x1024 monitor
That's an F in the profile pic
https://linustechtips.com/topic/691444-overclock-gtx-1060-boost/#findComment-8872364
I'm saving money right now to build a PC. Right now I'm using a laptop. My brother is also using the gtx 1060, and we both wanted to know.
https://linustechtips.com/topic/691444-overclock-gtx-1060-boost/#findComment-8872374
I wouldn't recommend running it OC'd from the beginning, it seems like you don't have the cash flow to upgrade in 2-3 years. I just OC'd to see what I got and then went back to stock
I have a 6600 and a 1060. It's a really good combo. Good luck on your PC!
https://linustechtips.com/topic/691444-overclock-gtx-1060-boost/#findComment-8872394
