Any be quiet case should do the job:
http://www.bequiet.com/en/case/594
Honestly It's not only the case getting good fans that are made  to reduce the sound as it pushes air through the case as well as a fan controller does help. I personally just water cool my systems
https://linustechtips.com/topic/691438-noise-dampening/#findComment-8868390
1 minute ago, Astonuats said:
if you want to go for a one hundred usd case you could go with the cooler master master case 5. you can wake it so it has more room to put more foam in.
would this work Corsair Carbide Series 100R Silent Edition Quiet Mid Tower Case
it is 60$
https://linustechtips.com/topic/691438-noise-dampening/#findComment-8868394
have fan controller it si gpu  that make the noes
can not afford water cool
https://linustechtips.com/topic/691438-noise-dampening/#findComment-8868404
7 minutes ago, m2234323 said:
what is a good noise dampend case to get for http://pcpartpicker.com/list/nwXLPs
or to put sound damping foam in this case
Usually it is best to invest in quieter hardware over noise dampening foam but a good quite case is the Define R5.
https://linustechtips.com/topic/691438-noise-dampening/#findComment-8868412
Then get a be quiet case or like suggested above get a cooler master case to put foam in. And may I recommend setting a fan profile on the GPU with MSI Afterburner, with some testing you can get temperatures you're comfortable with whilst keeping the fans at a lower speed. I personally don't mind the sound and keep my fans quiet loud.
https://linustechtips.com/topic/691438-noise-dampening/#findComment-8868442
try eather it is very loud or low fps in the game or not look good
https://linustechtips.com/topic/691438-noise-dampening/#findComment-8868452
