http://pcpartpicker.com/list/79btnn opinions?
And how does this goes with the build: Monitor and Cooler Master Devastator Keyboard + Mouse combo
How will this run triple A titles like battlefield? GTA V, Mafia 3, Rocket League, Just Cause 3, Gears of Wars, The Division, and Doom, etc.
https://linustechtips.com/topic/690488-first-build/
Good build, but you don't need 16gb of ram or the thermal paste, it's pre-applied on the cooler.
EDIT: With your budget, I would throw in an ssd.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/690488-first-build/#findComment-8857349
3 minutes ago, deXxterlab97 said:
You don't need a 212 Evo because i5 6500 comes with Intel stock cooler and should be fine for you. Rest looks good to me and the monitor is great too
Does the stock cooler perform well? And does it give good temps.
Also will I need any extra case fans, or no?
https://linustechtips.com/topic/690488-first-build/#findComment-8857368
SPECS:
https://linustechtips.com/topic/690488-first-build/#findComment-8857371
I'd say hold off on the cup cooler and extra fans. You probably won't need it. If temps aren't to your liking extra fan and cup cooler would probably take temps down a bit.
thermal paste is included, not applied, but not difficult at all.(hyper 212)
SSD would be nice, but only if it's in your budget, not at all necessary but a very nice upgrade.
gaming really don't use more than 8gb, usually, at 1080p 8gb hsould be fine,
https://linustechtips.com/topic/690488-first-build/#findComment-8857451
ty
https://linustechtips.com/topic/690488-first-build/#findComment-8857489
