9 minutes ago, Haloman1911 said:
I have a old hard from 2 years ago in my old pc I'm making a new but don't know of I can use my old hard drive in my new pc and still haves windows
You may have to reactivate or call [Microsoft]. Just tell them that your motherboard died and you needed a new one.
Edit: Derp.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
10 hours ago, Haloman1911 said:
~snip~
Hi there :)
As @deXxterlab97 suggested, you may need to get a new copy of the OS. I'd check the licence you have and see if you can reuse the Os key that you currently have to make a fresh install on the new hardware.
Generally, you can't simply take the old drive and put it in the new build and boot the OS. When installing a OS it is adjusted to the specific hardware it is being installed on and even if the new hardware is close as specs the the old one you may still notice errors, BSODs, unstable behavior and other problematic situations even if you manage to boot from it so a fresh install of the OS is recommended. This will also create a new registry so you need to reinstall all your games and applications too.
You can still reuse your old drive and access the data on it. You need ti simply put all data on a second partition and wipe the OS partition through the Os installer when placing the new OS on the drive. The secondary partition should stay intact.
What's the drive's brand and model? I would strongly recommend checking its health with a manufacturer too land see the S.M.A.R.T. status and the overall condition of the rive before trusting it with data from your new build.
Let me know if you need any help!
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
