So im building a relatively cheap build and i need opinions on it and to make sure it will all run smoothly.
The build is:
CPU        -Intel Core i5-4460 3.2Ghz                    -https://pcpartpicker.com/product/F63RsY/intel-cpu-bx80646i54460
Motherboard-Asus h81m-plus                              -https://pcpartpicker.com/product/FBNp99/asus-motherboard-h81mdplus
RAM        -8GB 1600Mhz DDR3 Crucial Ballistix  -https://pcpartpicker.com/product/TP648d/crucial-memory-bls2kit4g3d1339ds1s0
GPU        -Sapphire AMD RX460 Nitro+ 4 GB      -https://www.amazon.co.uk/gp/product/B01J1J7WOM/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE
Case       -CiT F3 White Midi Gaming Case         -https://www.amazon.co.uk/gp/product/B01BLI50WM/ref=ox_sc_act_title_4?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE
storage    -WD green 500gb (borrowing)             -https://pcpartpicker.com/product/wRtCmG/western-digital-internal-hard-drive-wd5000aacs
PSU        -Corsair VS450                                     -https://pcpartpicker.com/product/k72kcf/corsair-power-supply-cp9020049ww
display    -Iiyama ProLite E2480HS-B2 24-Inch  -https://www.amazon.co.uk/gp/product/B018SMN1W0/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE
cooling    -Intel stock cpu cooler
Os         -Windows 10
Total is around 500 - 600pounds.
Thanks in advance
https://linustechtips.com/topic/690454-need-opinions/
The build is:
Os         -Windows 10
Thanks in advance
get a cxm450 for the psu
https://linustechtips.com/topic/690454-need-opinions/#findComment-8856962
Use the text button at the top of PCpartpicker page, this is very hard to read. Get a better PSU, CX or B2 perhaps. I would also add an SSD and a larger HDD, 500Gb isnt much.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/690454-need-opinions/#findComment-8856964
It looked a lot better when  i was writing it. Ill eventually invest in a better PSU and the hdd ill be using wont even be mine itll just help me start off
https://linustechtips.com/topic/690454-need-opinions/#findComment-8856975
3 minutes ago, Cosmopath said:
PCPartPicker part list: http://uk.pcpartpicker.com/list/TvZm3F
Price breakdown by merchant: http://uk.pcpartpicker.com/list/TvZm3F/by_merchant/
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  (£105.59 @ Novatech)
Motherboard: Asus H110M-K Micro ATX LGA1151 Motherboard  (£47.99 @ Amazon UK)
Memory: Kingston FURY 8GB (1 x 8GB) DDR4-2133 Memory  (£34.99 @ Novatech)
Video Card: Zotac GeForce GTX 1050 Ti 4GB Mini Video Card  (£134.99 @ Ebuyer)
Case: BitFenix Nova ATX Mid Tower Case  (£26.99 @ Novatech)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  (£44.99 @ Overclockers.co.uk)
Operating System: Microsoft Windows 10 Home Full 32/64-bit  (£83.90 @ More Computers)
Monitor: Samsung S22D300HY 21.5" 60Hz Monitor  (£80.99 @ CCL Computers)
Total: £560.43
Generated by PCPartPicker 2016-11-13 22:58 GMT+0000
aprerciate the time and effort you put in but ive already got some of the parts and this wouldnt work out any cheaper
https://linustechtips.com/topic/690454-need-opinions/#findComment-8857022
Just now, Cosmopath said:
More information would be nice. What parts do you own already? How much are you looking to spend excluding the parts you already have? You didn't include this in your original post so I had no idea what to do.
I know my bad, my apologies. I have the cpu, ram, motherboard, cpu cooler and hdd. I still need my gpu, my case, my psu, monitor and my own hdd as im borrowing the wd green (total excluding the parts i have is around 310 pound because i changed my psu to a cx450m)
https://linustechtips.com/topic/690454-need-opinions/#findComment-8857046
11 hours ago, Cosmopath said:
PCPartPicker part list: http://uk.pcpartpicker.com/list/LwmzkT
Price breakdown by merchant: http://uk.pcpartpicker.com/list/LwmzkT/by_merchant/
Video Card: MSI GeForce GTX 1050 Ti 4GB Video Card  (£139.98 @ Ebuyer)
Case: CiT F3 White Midi Gaming Case (£24.01)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£49.99 @ Novatech)
Monitor: BenQ GW2470H 23.8" 60Hz Monitor  (£100.44 @ Amazon UK)
Total: £314.42
Generated by PCPartPicker 2016-11-13 23:17 GMT+0000
GTX 1050Ti performs about 30-40% better than the RX460. It's an upgrade worth the extra ~30 pounds.
The Samsung monitor has identical specs to the monitor you chose (response time is actullly lower, too) is by a much more reputable company, and is quite a bit cheaper.
If I'm not mistaken, I believe you didn't include a hard drive in the 310 pounds? I don't believe an RX 460 + the monitor you chose would be cheap enough to fit in a hard drive in the 310 pound range.
That monitor is perfect. Thank you
https://linustechtips.com/topic/690454-need-opinions/#findComment-8859280
