hi i recently have a problem with my GPU and it happened thrice. it started to spin at 100% fan speed and the screen goes black.
1st time:
i was doing some basic task (browsing) then suddenly everything stopped and the gpu fans started to spin at 100% and the screen goes black. i have to manually shut it down using the power button on the case.
2nd time:
same thing as the 1st time but now sorting my files on my computer
3rd time:
i was doing some heavy gaming then i tried to shut down (but this time normally) the screen turned off but the GPU fans started to spin at a faster speeds i left it for a couple of seconds then shut it down manually again
anyone know whats going on with this?
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/690051-gpu-problem/
1 minute ago, GalacticRuler said:
Sounds like a power supply problem. Do you have another power supply or a tester you can use?
no psu tester.... and not other psu
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/690051-gpu-problem/#findComment-8853135
Looking at your description, I'd say it's either the sensor on the card falsely reading high temperatures , causing it to shut itself down to protect the card, or the cooler is not seated properly on the card, which is unlikely. Try returning it to where you bought it or contact Asus. Also check that you have enough airflow in the case, so that it's not just reusing its own hot air.
That's an F in the profile pic
https://linustechtips.com/topic/690051-gpu-problem/#findComment-8853140
I monitor the temperatures every time i can. it seems to be sitting at 31 degrees celcius at idle and 50-59 on load, i dont think the sensor will be the issue since i tested it on 3 different softwares (asus gpu tweak, msi afterburner, and gpu-z) they give almost identical readings. and i am certain my case has good airflow. but thank you for your reply
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/690051-gpu-problem/#findComment-8853155
Check that you have the latest drivers, otherwise I'd recommend just returning it. A 1060 with such a beefy cooler should never get hot
https://linustechtips.com/topic/690051-gpu-problem/#findComment-8853164
I downloaded the latest nvida drivers (375, i think its the lastest). i may return it if it does it again.
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/690051-gpu-problem/#findComment-8853175
