That isn't bad at all. This is a perfect indication that your CPU cooling is working well. Web browsing requires alot of computing, look at your performance page (assuming Windows 10) and see how much CPU and memory you use while surfing the web.
If you didn't have cooling your CPU would go to 90 deg C in seconds. 26 is a good idle temp.
https://linustechtips.com/topic/689808-is-this-a-problem/#findComment-8850586
