my budget is around 250 or less, i am trying to find new or used (new prefer) i5 + mobo, or zeon +mobo.
to elaborate on why , i have a 8350 that has not wanted to work correctly, i have a gtx 970 to pair with it but it doesn't work to well. for me specifically i play league and do so competitively and i cant play hardly because league almost maxes out 1 core and leaves a second core at 50 percent then my other 6 cores arent at any load hardly, the problem is when someone casts a spell there is a massive drop in frames from 300 or so to 18 , this leaves several seconds for of really choppy ness, and i get at times where ill cast a spell then it wont show the effect and it will just happen no animation , this is preety bad for me now with the preseason patch, i used to be a akali main so when you go in your really threading the needle. this could be a mobo or cpu problem , and i really dont have any funds to just buy one or the othere. i would like just a fresh start , and allmost everyone says to get a i5. and also i have major audio and video unsync in most open world games , i cant hardly play them because cut scens are fucked. and i get insanely low fps in wow , so it all point to cpu and hopefully that the problem. i do edit video and have thought about zeon procesor, but at this point i just want something that works and will keep up with my 970. it hard to play a competitive match ( for a actual team) when your having issues that cant be controlled at the time, have defiently lost games when in a big team fight and everything derps out and i cant combo or even see whats going on.
my current build is
8350 @4.0 (have gone all the way up to 5 and it litteraly doesnt help the problem)
asus r2.0 pro mobo
gtx 970 msi (none gaming)
1866 ddr3 ram
700 watt psu ( bought it because it was on sale)
windows 10 pro ( have tried all forms of windows and it doesnt help)
any help would be appreciated, i am a really big believer in amd build for budget gaming but i havent had time to do any research on this exact topic.
https://linustechtips.com/topic/689785-help-with-part-finding/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($191.89 @ OutletPC)
Motherboard: ASRock H110M-HDV Micro ATX LGA1151 Motherboard  ($58.98 @ Newegg)
Total: $250.87
Generated by PCPartPicker 2016-11-12 13:06 EST-0500
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/689785-help-with-part-finding/#findComment-8850374
