Hard drive not showing up
Go to solution Solved by Cyracus,
Just now, ToastyTavi said:
when I right click on it the only 2 options are properties and "new simple volume"
ok, click new simple volume and go through the setup and that should have it working then, sorry, working half off 6 month old memory from
2 hours ago, Electronics Wizardy said:
did you open it?
right click on the drive and then new volume.
The problem is that I can't open it. It is recognized in the bios but wont let me do anything to it in the bios. It won't show up while I'm in windows
4 minutes ago, ToastyTavi said:
I DONT KNOW
ok, calm down, what OS are you on?
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
right click on the win 10 logo and select disk management from the menu, on the bottom menu it should have your drive as something (maybe blank space or unpartitioned) right click and select the option to mark as active and I believe that should get you going
desktop
HTPC
6 minutes ago, ToastyTavi said:
get out of here if you are gonna be a douchebag and not help
I would help but you're clearly a nazi. Travel the internet waving a Nazi flag and expect not to get made fun of?
ψ ︿_____︿_ψ_
2 hours ago, EnemySp0tt3d said:
Clock on the windows tab in the bottom right corner, and type in "Disk" and then disk management shows up. Then right click on the drive that is black, and format it.
desktop
HTPC
8 minutes ago, ToastyTavi said:
ITS A PC MASTER RACE MEME
I dont care what you acquired from other ten year olds off the internet. learn your history. dont flash a nzai flag on my screen and ask for help
ψ ︿_____︿_ψ_
It is not a nazi flag, regardless pretty much every fascist country used this style of flag and not just germany. I understand my history and I have studied WW2 germany's weapons, tactics, politics, etc. so fuck right off there. Stop complaining because I have a meme as my pfp
1 minute ago, ToastyTavi said:
It's not nazi master race you autist, its a PC master race MEME
Calling me an autist indicates you subscribe to the Nazi attitudes towards disabilities.
Thank you for disclosing you think it is ok to use a nazi style flag because the facists use it.
It is good that you do not hide your facist and Nazi beliefs, this way we know who you are.
Keep going through life waving your Nazi flag on armistice day, wondering why people don't want to help you.
ψ ︿_____︿_ψ_
