So you're confident it's not drivers, thermal, or malware. Captain obvious can't help you here; but here are my thoughts/brain-farts:
Have you performed benchmarks to identify which hardware is playing up? You said you did some after burner stats; I'm wondering how does your CPU and GPU compare in benchmark tests to others with same hardware? I use linux so I use openbenchmark.org to check hardware; theres a ton of similar benchmark sites for Windows and I suggest you check them all.
Wouldn't hurt to also test your RAM and hard drives. There was an issue with Samsung's 840 SSD that caused computers to slow down after a few months of use.
Sometimes anti-cheat software plays up.
Sometimes anti-virus plays up.
Sometimes background software updates play up.
What is your computer resource usage at idle? (ram & cpu & network)
ψ ︿_____︿_ψ_
ram and cpu at idle isn't usually any higher than 15% e.g youtube and stuff and for network, i dunno, i mean i never lag in games and can stream fine soooo...
1 hour ago, Dalynx said:
Make sure to try your bridge first mate as i don't wanna waste your time on my shit when you have problems, the new bridge of course lol
i get around 60 with a single 660 maxed out 1080p, im pretty sure your card is bad lol
Builds:
2 minutes ago, Jorgen297 said:
Well if you want to make sure it's not a false claim, reformat, then you're pretty sure. Anyways your attitude towards the possibility of it might being malware is oblivious, AVG fucking sucks cock. I ran it for 2 years, then I ran the ESET free one time scan and had like 12 malwares. So at least run this https://www.eset.com/us/online-scanner/ if you don't wanna reformat.
trying the site now
its halfway through and seems okay at the moment
Just now, Dalynx said:
damn, what was your lowest?
didnt do a benchmark but it felt like nothing bellow 50 fps with most of it beeing 60+
Builds:
my lowest was 80, a 30 fps diff is way to low for a card like this, thanks so much by the way this should be enough evidence (i hope) if you  ever need any help with stuff like this just message me
no problem, glad to help :)
Builds:
2 minutes ago, Dalynx said:
would love to but until now no one suggested a malware help site, reposting brings new people, meaning new help, no one can deny that
2 hours ago, Dalynx said:
He then thought i could've had fucking malware which could bottleneck my cpu, i quickly shut that idea down with some afterburner stats (Malware, what kinda shit is that to think off).
You have said a few times you're confident its not malware. If you say its not malware then I can only take your word for it and my efforts will turn to other potential solutions. This makes me confused on what you have and have not done to test your hardware & software.
It really doesn't make it easy to help you when you have two posts for one issue.
Thats not enough. Please do a proper test & benchmark so we can eliminate faults from anything other than your GPU hardware.
Here is what i use http://www.phoronix-test-suite.com/?k=pts_desktop_live . Results from other users of this test suite can be found on openbenchmark.org
There are a ton of other benchmarking suites but I can only recommend what I use.
ψ ︿_____︿_ψ_
i really hope this is safe i hate downloading random poop
which version of it should i get
Its open source. costs nothing. adware & malware free.
You really need to read the documentation first. If its too much for you then you should look for alternatives; for windows there are many, many alternatives that you can find on google but I can't give you a recommendation for software I do not use. I used Steam's benchmarking in the past but I can't seem to find it; they may have discontinued it.
ψ ︿_____︿_ψ_
Reinstall windows
System
  • CPU
    I7 6700K Overclocked to 4.6 GHz at 1.33v
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
    GSKILL RIPJAWS V DDR4 16GB 3000MHZ
  • GPU
    MSI GTX 1070 GAMING X 8G overclocked to 2063 MHZ and 8900 MHZ memory clock
  • Case
    NZXT S340 RED
  • Storage
    WD 1TB BLUE AND SAMSUNG EVO 250GB SSD
  • PSU
    EVGA 650W GQ
  • Display(s)
    LG 25UM58-P ULTRAWIDE and LG 29UM58-P 29 ULTRAWIDE
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
    LOGITECH G502 PROTEUS SPECTRUM
  • Operating System
    Windows 10 PRO
