So I have a friend with this monitor Sony SDM-HX95, and windows set it to 60Hz.
The person complaint to me when I installed the new vga that the pics was different, somehow, and after messing about the monitor was set to 75Hz, and the issue was over.
Can displays run over spec Hz? If they do is there a risk of damage?
Thanks for the time.
https://linustechtips.com/topic/68932-help-60hz-versus-75hz/
Yes displays can be overclocked. I don't know if there is any danger (probablly but that would be minor) I oc my displaly and a lot of my friends do the same. (No problem what so ever)
My Pc: Cpu: I7 4790k @ 4,8 Ghz @1,25 volts, Motherboard: Maximus VII Formula, Graphicscard: 2x Titan X @1,4 at stock voltage (soon to be replaced), Ram: 32 gb Corsair Dominator Platinum 2133 Cl 9, SSD: 2x 850 Pro 1 Tb in Raid 0, 2x Samsung 840 Evo 1 tb raid 1,, PSU: Corsair HXi Series 1000W 80+ Platinum, Case: H440. Soon to be watercooled again, maybe, probably, the Titans are too loud.
https://linustechtips.com/topic/68932-help-60hz-versus-75hz/#findComment-945253
They can, but there is an inherent risk.
https://linustechtips.com/topic/68932-help-60hz-versus-75hz/#findComment-945255
