Hi, I want am going to build a computer in the Phanteks Eclipse p400S and want to get the Phanteks LED strips that can connect to the case since it has strips on the front of the case. I was wondering, how much LED strip do I need just to cover the sides, top and bottom of the case?
https://linustechtips.com/topic/688722-how-much-led-do-i-need/
I just put one on the top
Lots of people overdo on LED strips and make the lights WAY too bright, you want to keep it minimal and let it be a ambient light instead of a damn lightfest rave (I mean you could if you wanted)
https://linustechtips.com/topic/688722-how-much-led-do-i-need/#findComment-8839397
But what if i am an avid listener of skrillex?
https://linustechtips.com/topic/688722-how-much-led-do-i-need/#findComment-8839430
23 hours ago, Cohacq said:
All of it!
So what length would you recommend?
https://linustechtips.com/topic/688722-how-much-led-do-i-need/#findComment-8845381
