So I just did a fresh install of 7 and I'm going through the laborious task of setting everything back up. Since this is a fresh install my storage drives have all been assigned new letters, this urkes me but not a problem... or so I thought when I went to change the drive letters as I have done many times on previous builds pretty much every letter apart from the one I want has shown up why is this happening !?!
I want D BTW
There are 10 types of people in the world: those who understand binary numbers and those who don’t
bulgara, oh nono
Multipass
https://linustechtips.com/topic/688128-drive-letter/
If I'm not wrong D: partition will be the system reserved one, and you won't have the option to change. BTW, why do you need that drive so siriously to be drive D:, it's just a denomination thing
Case: NZXT phantom CPU:I5-4460 GPU:MSI-GTX1070 Gaming X RAM:2x4Gb-DDR3-HyperX fury MOBO:Asus Z97-P HDD:Toshiba 1Tb 7200rpm PSU:Sentey650W
https://linustechtips.com/topic/688128-drive-letter/#findComment-8832178
I want D BTW
What letter is System Reserved assigned too
https://linustechtips.com/topic/688128-drive-letter/#findComment-8832193
It's always been D... I'm a bit OCD Isn't the system reserved letter C?
bulgara, oh nono
Multipass
https://linustechtips.com/topic/688128-drive-letter/#findComment-8832196
No, the drive where all the OS is stored is C, the system reserved is the 100Mb partiition that windows will define as D
https://linustechtips.com/topic/688128-drive-letter/#findComment-8832200
It doesn't have a letter I was just assuming it shares C as it's only a partition.
bulgara, oh nono
Multipass
https://linustechtips.com/topic/688128-drive-letter/#findComment-8832203
It doesn't show a letter I thought it just shared C as it's just a partition? I have the option to change it but it's empty atm.
bulgara, oh nono
Multipass
https://linustechtips.com/topic/688128-drive-letter/#findComment-8832209
Yes, idk why it doesn't show in your pc with the letter D, but you can indeed see that in disk 2 you have C: partition and the system reserved partition, that, even though it doesn't show it's identified as D:
https://linustechtips.com/topic/688128-drive-letter/#findComment-8832219
Awsome thanks for the help.
bulgara, oh nono
Multipass
https://linustechtips.com/topic/688128-drive-letter/#findComment-8832221
Nope that didn't help and I'm now pretty certain you're not supposed to assign disk letters to system reserved partitions as it makes the partition show up as a drive in your explorer window deleted it and restared windows everything seems to be fine it did give me a pretty serious looking warning window about how changing the drive letter can f**k up programs etc but I'm sure it's fine lol.
bulgara, oh nono
Multipass
https://linustechtips.com/topic/688128-drive-letter/#findComment-8832244
Sorry to keep pestering you guys but I thought I'd update you solved the problem my phone had been assigned the letter D but as it was a recognised device was showing as Samsung Galaxy s6 hence why I never realised pretty stupid on my part but hey it's sorted only took half an hour longer than it should have.
bulgara, oh nono
Multipass
https://linustechtips.com/topic/688128-drive-letter/#findComment-8832286
The system reserved partition isn't assigned a drive letter, and cannot be assigned a drive letter. Drive letters aren't used to identify the drives and partitions at the OS level, it identifies them as volumes, following the disk and partition order. The first disk is identified as disk zero, and the first partition as volume zero. It continues this pattern with all partitions of disk zero, then moves onto disk one's partitions.
If D: isn't available, it's because another device has been tied to that letter.
C: is a different partition than the system reserve. It's entirely possible that a network device or removable device has been tied to D:.
Come Bloody Angel
Break off your chains
And look what I've found in the dirt.
Pale battered body
Seems she was struggling
Something is wrong with this world.
Fierce Bloody Angel
The blood is on your hands
Why did you come to this world?
Everybody turns to dust.
The blood is on your hands.
The blood is on your hands!
Pyo.
https://linustechtips.com/topic/688128-drive-letter/#findComment-8832312
Thanks little to late though :P sorted it out had my phone plugged in I feel stupid.
bulgara, oh nono
Multipass
https://linustechtips.com/topic/688128-drive-letter/#findComment-8832322
Won't lie, completely forgot that Windows 7 assigns drive letters to phones. I've gotten used to Win10 listing phones and some media players listing them as such.
Come Bloody Angel
Pale battered body
Fierce Bloody Angel
Pyo.
https://linustechtips.com/topic/688128-drive-letter/#findComment-8832332
I was thinking the same as 7 does display it as a device but secrety assigns it a letter.
bulgara, oh nono
Multipass
https://linustechtips.com/topic/688128-drive-letter/#findComment-8832355
