Workstation build.
Solved by Xanthe_2871,
6 minutes ago, BlackWorm said:I’m looking for a workstation computer to run heavy desktop applications as cheap as possible.
How about something like this?
http://pcpartpicker.com/list/p9YXnn
You really don't need 32 GB of RAM for what you're talking about using the PC for, but if you insist, try this build:
