hey guys i buy cd's for all my music and i convert them at 320kbps into itunes. However when i transfer the music to my htc one it has to convert the files to a format which the htc supports and i think it may be lowering the quality and adding in some static especially in the highs. Could this be possibly or is it me just being paranoid and picky. Btw its not the headphones, i ruled that out. It just seems like its happening on all itunes music.
CPU: i5 4670k with Noctua C12P-SE14 GPU: Gigabyte GTX 770 SSD: 250gb Samsung EVO MOBO: MSI Z87-G43 RAM: 8GB G-Skill 1600mhz PSU: Antec HCG 620W CASE: Corsair 300R windowed
https://linustechtips.com/topic/68741-itunes-audio-conversion/
iTunes rips into an m4a extension. Rip with a third party to MP3, and add that into iTunes
"Say it, do it, preach it, shout it, but never, absolutely never, believe your own bullshit"
Credited with the whole female avatar trend
Your thoughts here http://linustechtips.com/main/topic/67178-your-top-three/
https://linustechtips.com/topic/68741-itunes-audio-conversion/#findComment-942373
any recommendations on third party software or do they all just do the same job
https://linustechtips.com/topic/68741-itunes-audio-conversion/#findComment-942379
I've used both EAC and dbpoweramp. Currently I use dbpoweramp to rip into raw waveforms, and convert to MP3 320 in xrecode ii
https://linustechtips.com/topic/68741-itunes-audio-conversion/#findComment-942382
Foobar2000 and winamp are big ones.
https://linustechtips.com/topic/68741-itunes-audio-conversion/#findComment-942407
sweet ill download dbpoweramp :)
https://linustechtips.com/topic/68741-itunes-audio-conversion/#findComment-942412
Depends. By default, probably.(Can't remember)(And when downloading things off of iTunes.) But you can set it to convert to different formats like WAV.
https://linustechtips.com/topic/68741-itunes-audio-conversion/#findComment-942457
Definitely not .wav. iTunes itself won't support it, instead I'm forced to convert those to ALAC.
https://linustechtips.com/topic/68741-itunes-audio-conversion/#findComment-942459
I've used iTunes to convert MP3 and AAC songs to WAV before. And I've imported CDs using WAV. iTunes supports WAV.
https://linustechtips.com/topic/68741-itunes-audio-conversion/#findComment-942467
