is my thermal paste bad? it keeps drying up( in the center)  and having to replace it every other day (almost out) the tube i got was Thermaltake TG-7, my cooler the the corsair h80iv2, I've re-seated and re-seated the cooler a thousand times, so there is no air, the cpu temps are normal untill they are not any reason why? or just a bad paste
i7-7700k @4.8GHz
Asus Maxmius IX hero
EVGA GTX 1080Ti FTW 3
850w EVGA PSU
32GB corsair LPX ddr4 ram
https://linustechtips.com/topic/687377-thermal-paste-issue/
This paste is bad because it likes to dry up and spike the CPU temps. Consider finding yourself a different paste.
lttstore.com
https://linustechtips.com/topic/687377-thermal-paste-issue/#findComment-8824038
"The temps are normal until they are not", what does that even mean?
Thermal paste can get dry, why are you removing the cooler and checking every day? That brings up a host of its own problems. Apply it once, and leave it unless temperatures start getting uncomfortably high. Reseating the cooler over and over will add air bubbles you know.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/687377-thermal-paste-issue/#findComment-8824039
the temps are normal like 28c 22c per core then the spike up to 68-72c per core wile idle and i don't like that
i7-7700k @4.8GHz
850w EVGA PSU
https://linustechtips.com/topic/687377-thermal-paste-issue/#findComment-8824044
when under load? Thats normal.
https://linustechtips.com/topic/687377-thermal-paste-issue/#findComment-8824050
nope
at 2-5% cpu load
then it sounds like the cooler is barely attached, it should be mounted down very firmly, you shouldn't be able to move/twist it.
https://linustechtips.com/topic/687377-thermal-paste-issue/#findComment-8824067
what paste do you recommend
i7-7700k @4.8GHz
850w EVGA PSU
https://linustechtips.com/topic/687377-thermal-paste-issue/#findComment-8824071
Well, no. If you keep re-seating it, there definitely is air now than before.
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/687377-thermal-paste-issue/#findComment-8824072
1 minute ago, suchamoneypit said:
then it sounds like the cooler is barely attached, it should be mounted down very firmly, you shouldn't be able to move it.
can't move the cooler one mm
i7-7700k @4.8GHz
850w EVGA PSU
https://linustechtips.com/topic/687377-thermal-paste-issue/#findComment-8824079
