i'm pretty sure the general rule for gpu's is 80 and under is fine
CPU: i5 4670k with Noctua C12P-SE14 GPU: Gigabyte GTX 770 SSD: 250gb Samsung EVO MOBO: MSI Z87-G43 RAM: 8GB G-Skill 1600mhz PSU: Antec HCG 620W CASE: Corsair 300R windowed
https://linustechtips.com/topic/68733-safe-temps-for-7970/#findComment-942202
Wait...using a 7970 with XFX's DD custom cooling solution, and you're reaching 80*C??
What computer case are you using? How is the airflow inside your system?
What speed are you fans get to?
80*C is well within the same operating temperature limits...but it's only got a mid overclock on it.. 1075 / 1500...
My Sapphire Dual-X 7970 OC'ed to 1140/1480 is much lower in temperature during 100% load (Furmark)...
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/68733-safe-temps-for-7970/#findComment-942829
XFX coolers tend to load around those temps so its fine imo. I would stay below 90C to be safe.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/68733-safe-temps-for-7970/#findComment-942831
Terrible case, terrible airflow, and I start crashing in CCC at 1085, so I can't go any higher. And yes, it is XFX DD non-ghz edition, my other 2 friends that have the same card (XFX DD Non-GHZ) only get 975 and 1025 so I feel lucky with my 1075 xD
https://linustechtips.com/topic/68733-safe-temps-for-7970/#findComment-942993
