What CPU and what mobo?
https://linustechtips.com/topic/687326-32bit-to-64bit/#findComment-8823432
2 minutes ago, Fluxus said:
IF I have a 32bit CPU installed in a mobo can I just change it and add a 64bit CPU with no problems? Do I have to reinstall windows?
It depends on the architecture. You make it sound design like you're using some legacy hardware. You're going to have to specify your hardware so we can give you a correct answer.
https://linustechtips.com/topic/687326-32bit-to-64bit/#findComment-8823446
Just now, Fluxus said:
It's an old Core 2 Duo E7400 machine. I want to use it as a home theatre machine. I got a deal for a Q8200 so I'm wondering if I can just swop CPU's without having to reinstall windows.
The Q8200 can also run 32-bit windows. So you should be fine. (although there can sometimes be issues running an old-windows install with new hardware).
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/687326-32bit-to-64bit/#findComment-8823476
Swapping CPU's should work, but youll still have 32-bit. Switching between architectures REQUIRES a re-install. It cannot be "upgraded"
That being said, running 64-bit wont really change anything besides allowing you to have more than 4bg of ram.
When in doubt, re-format.
https://linustechtips.com/topic/687326-32bit-to-64bit/#findComment-8823481
If the socket is the same it should work just fine. You may not need to reinstall windows, however if you don't you'll be running a 32 bit version of the OS regardless of what your cpu is capable of.
With all of the above in mind, your current cpu is actually 64 bit as well. Not sure why you think otherwise.
sudo chmod -R 000 /*
https://linustechtips.com/topic/687326-32bit-to-64bit/#findComment-8823486
64 bit cpus can run 32 bit software.
Should work fine.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/687326-32bit-to-64bit/#findComment-8823492
Oh shit, facepalm. I just found that out right now :P I guess the previous owner of this machine did the same thing i wanna do. Thanks to all that helped.
https://linustechtips.com/topic/687326-32bit-to-64bit/#findComment-8823908
