Hi!
Lately I feel like my headphones (Just regular phone ear buds) are producing low volume on my pc, and I was wondering: Is the max volume I can hear determined by the headphones, sound card, or both? I feel like I should mention that when I use my phone I can hear louder, but I still I don't think it's only the sound card that is the problem, but the combination.
https://linustechtips.com/topic/687184-max-volume/
Well, the PC kinda determines how loud it's going to play. But if you have for example a volume wheel on your headphones/earbuds that also makes a difference. There are ofc softwares that help you boost sound but often it just makes quality go downhill.
___________
Jonas
| Intel i5 4670k @ 4.3GHz | XFX RX 480 8 GB | Asus Z87i-Pro | 8.0 GB Kinston DDR3 | Samsung Evo 120GB SSD |
https://linustechtips.com/topic/687184-max-volume/#findComment-8821760
yes it is the combination. if the sound card cant supply enough power for the drivers then you will get less sound. if the headphones have small drivers... well you basically have the same thing
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/687184-max-volume/#findComment-8821767
And if I buy new headphones, how can I know if the sound card in the motherboard is enough? (The mobo doesn't have a model, it's a prebuilt pc)
https://linustechtips.com/topic/687184-max-volume/#findComment-8821783
i would suggest downloading cpu-z to know what is your mobo.
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/687184-max-volume/#findComment-8821790
