Hi, I just installed NZXT CAM software today. After installing it, it prompted me to update but the installation requires a reboot. So I rebooted first then updated the software. Now, after updating to the latest version, it seems that the software is not working. It is stuck in the log-in screen after inputting my accout information. I reinstalled the software again and not updating it and it works fine. The change logs of the latest update is what I'm after since it reduces the use of resources.
I tried terminating the software and made a re-run and now it's stuck on loading the software turning the login screen white with a loading progress of "65%".
Any tips/suggestions/solutions is highly appreciated. Thanks in advance.
Attached here is the photo of the problem.
I'm currently using windows 10 64-bit.
UPDATE: No reply from NZXT Support. Still waiting.
UPDATE 2 :  My ticket was suddenly removed without my consent from NZXT. Anyway, I found another software to use. Thanks.
CPU - Intel i5-6400
GPU - MSI GTX 1050ti Gaming X 4GB
PSU - Seasonic 620w S12-Evo
RAM - Avexir 8GB 2 x 4GB
CHASSIS - Phanteks Enthoo Pro Full Tower (White)
MONITOR - Samsung 32" 1366 x 768 | AOC 1920 x 1080 21.5"
KEYBOARD - Corsair K70 Rapid Fire (non-rgb, RED)
MICE - Logitech G402 Hyperion Fury
MICE PAD - Corsair MM200
HEADSET - Kingston Hyper X Cloud Core
 SnarkyGame
https://linustechtips.com/topic/687073-nzxt-cam-software-issues-need-help/
Have you tried contacting NZXT so they can fix the bug?
Hi, thanks for the reply. I haven't contacted them yet since I needed to register myself to their forums. I find the LTT community to be better in terms of this issues from my experience.
CPU - Intel i5-6400
 SnarkyGame
