Hi! I'm planning on building my first PC. I'm concerned about compatibility and bottlenecks (I have 0 experience) Any recommendations? It will be used for gaming in 1080p and editing pictures only and I can't afford much more. I appreciate any constructive criticism! http://pcpartpicker.com/user/Tancio/saved/JMmgsY
https://linustechtips.com/topic/687061-my-first-build/
Don't get a z170 motherboard, it is useless (unless you want to spend extra on a 6600k). Get a h110 b110 or h170 motherboard instead. I would pay a bit more for 6500 to get extra closck speed
V300 is a bad SSD
Get an EVGA G2 or cheaper would be Corsair CX550M or Seasonic S12II because the one you have is bad psu
Also no need for an extra cooler since 6500/6400 comes with one.
https://linustechtips.com/topic/687061-my-first-build/#findComment-8820647
If you aren't going to be overclocking then you don't necessarily need a z170 mobo and you could go with a h110. mobo doesn't come with a wifi card incase you weren't planning on using Ethernet only, not sure you knew if it's your first build. (I didn't my first build)
I'd suggest the Hyper 212 Evo over the Cryorig H7, it's cheaper and it gets the job done. I'm curious why you choose the H7, I saw someone else use it in a build a few days ago and I thought if people were going cheap aircooling the Hyper 212 Evo was #1.
Your RAM is fine but you could drop the price by 8 USD with Corsair Vengenance LPX.
I'd either just buy a 7200 rpm HDD or put more money into an SSD because the V300 a good SSD.
Your case has two fans included and with the hardware you have you don't have a need for extra fans, one in front and one in back will work just fine.
CPU: I5-6600k | MOBO: MSI Z170-A XPOWER Gaming Titanium Edition | Cooling: Cooler Master Hyper 212 EVO |RAM: G.SKILL Ripjaws V Series 16GB DDR4 2800 | GPU: EVGA GeForce GTX 1070 SC GAMING ACX 3.0 Black Edition | Case: MasterCase Pro 5 | Storage: SAMSUNG 850 EVO 500GB, WD Blue 1 TB 7200rpm | PSU: EVGA SuperNOVA 750 G2 | Display: Acer Predator XB271HU 1440p 144hz | Keyboard:Logitech G910 Orion Spark | Mouse: Logitech G502 Proteus Spectrum | Headset: Logitech Artemis G933 | PcPP: http://pcpartpicker.com/list/sfgGjc
https://linustechtips.com/topic/687061-my-first-build/#findComment-8820677
V300 is a bad SSD
If he wants to use the Z170 features that the other boards don't have he can. Otherwise yes I agree with you on the motherboards and CPU choice.
I have a V300 and I agree it is not amazing.
The side window of the Carbide 400C would be a good reason to buy a cooler which looks nice (rather than stock).
I'd go with a cryorig C7, to show off more white but that's aesthetics, and not performance reasons. (if he needs to cut costs, then no 3rd party cooler is necessary yes)
https://linustechtips.com/topic/687061-my-first-build/#findComment-8820686
I would get this and hold off on the peripherals until you can afford them.
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($349.99 @ Directron)
CPU Cooler: be quiet! Dark Rock 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler  ($59.88 @ OutletPC)
Motherboard: MSI X99A Raider ATX LGA2011-3 Motherboard  ($152.98 @ Newegg)
Memory: Kingston FURY 32GB (2 x 16GB) DDR4-2400 Memory  ($152.98 @ PCM)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($94.89 @ OutletPC)
Video Card: Asus GeForce GTX 1070 8GB Dual Series Video Card  ($389.99 @ Newegg)
Case: NZXT S340 (White) ATX Mid Tower Case  ($66.69 @ SuperBiiz)
Power Supply: Corsair RM 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($59.99 @ Newegg)
Monitor: AOC i2369V 23.0" 60Hz Monitor  ($99.99 @ Best Buy)
Total: $1427.38
Generated by PCPartPicker 2016-11-06 23:50 EST-0500
https://linustechtips.com/topic/687061-my-first-build/#findComment-8820694
I'd try and go with at least a 6500 as mentioned by some of the other users.
I'd also drop the SSD for something like an MX300 if you're on a budget.
Drop the fans, they're not needed.
Use the money saved from dropping the fans on a better PSU. The 550W Seasonic G is on sale for $44 right now and is miles better than the one you selected.
Any particular reason you chose to go with the Z170 motherboard?
Total: $1427.38
Where are his headphones, keyboard and mouse?
The Seasonic G is $15 cheaper.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/687061-my-first-build/#findComment-8820734
Total: $1427.38
https://linustechtips.com/topic/687061-my-first-build/#findComment-8820740
get slightly cheaper peripherals and focus on the rest of the build instead.
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($328.99 @ SuperBiiz)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($29.90 @ Newegg)
Motherboard: MSI Z170A KRAIT GAMING 3X ATX LGA1151 Motherboard  ($112.98 @ Newegg)
Memory: G.Skill Ripjaws 4 Series 16GB (2 x 8GB) DDR4-3000 Memory  ($79.99 @ Newegg)
Storage: Crucial MX300 275GB 2.5" Solid State Drive  ($69.98 @ B&H)
Video Card: EVGA GeForce GTX 1070 8GB SC GAMING Video Card  ($389.99 @ B&H)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($44.99 @ Newegg)
Monitor: LG 23MP47HQ 23.0" 60Hz Monitor  ($110.98 @ Newegg)
Keyboard: Cooler Master Storm QuickFire Rapid Wired Gaming Keyboard  ($73.43 @ Amazon)
Mouse: Corsair M65 Wired Laser Mouse  ($39.99 @ Corsair)
Headphones: Logitech G35 7.1 Channel  Headset  ($52.92 @ Amazon)
Total: $1400.83
Generated by PCPartPicker 2016-11-07 00:38 EST-0500
https://linustechtips.com/topic/687061-my-first-build/#findComment-8820865
V300 is a bad SSD
I agree on the fact that there is no need motherboard, I just like how it looks (as well as the cooler). I'll take your advice and swap the PSU and SSD. Are sandisk SSDs any good? Are the cables in the seasonic psu black? I read they are, but I don't seem to find any pictures of it with flat black cables. Thank you!
https://linustechtips.com/topic/687061-my-first-build/#findComment-8822405
I bought the h7 just for looks. I'll take your advice and use the stock fans. I'm planning on buying an HDD. Corsair RAM is more expensive in my country (don't really know why). Thank you!
https://linustechtips.com/topic/687061-my-first-build/#findComment-8822422
I have a Sandisk ultra II and works really great
Most likely the cable are black
https://linustechtips.com/topic/687061-my-first-build/#findComment-8822424
Total: $1400.83
My little brother wants those peripherals and went as far as offering to pay for them. Won't argue with him bahaha. I'll swap the PSU and the SSD, though, thank you <3
https://linustechtips.com/topic/687061-my-first-build/#findComment-8822454
