Need Help Deciding on Final Parts for X99 Build
For the AIO go with the X61, better performer then your mentioned and not as expensive as the new follow up X62 (atleast here in NL since you talk in euro's). Also the NZXT ones can run more silent then the Corsairs The X52 is also new henche why so expensive because these where recently released. For performance overall the bigger rad the better since it's more area for cooling. The mentioned X61 has a 280 rad.
For CPU I would go 6800K. On it's own and for your work use it's a bit better performer and can atleast OC just as high or higher overall to what I read. But up to if you find it worth that extra dosh.
The 1070 seems like a fine choice. As for the 980Ti mentioned it really depends on use scenario: they are trading blows mostly. But there are some situations it seems where the 1070 shines over the 980Ti for his workloads. Combined with the better gaming performance (even though that is not highest priority) would stay with the 1070.
