So, ever since I rebuilt my computer, I've noticed my computer has been running a bit on the warmer side on idle. I didn't think much of it because I thought my fans were off when I was idle. However more recently, I decided to check out NZXT cam software. and noticed my fan curve was reset and my temps were still just as bad. Basically, my gtx 980 ti g1 gaming edition is running at 60 c on idle, with the fans at 40%, which I don't think they should be that high, but can anyone tell me what could be wrong if anything is wrong.
Additional Information:
Case: Fractal Design R5
Fan setup: 2 intake in the front, 1 intake in the bottom, 2 outtake through my top mounted radiator, 1 rear mounted outtake fan
GPU load on idle is at 2-3%
CPU temp is at 38 c on idle
GPU has been overclocked by 110 mhz on the core clock, and 150 on the memory and if the card runs at 90% or higher fans are set to max, thankfully the card only goes up to about 70 c
If you need anymore information, let me know.
https://linustechtips.com/topic/686505-components-running-a-bit-warm/
This is perfectly normal. Your GPU is designed to operate under 100 degrees C.
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
You're fine and don't need to change anything :P
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
Let's be more reasonable and say 85. I've seen my 560Ti become unstable at 90 degrees on an OC that is perfectly stable at 85.
Computer Specs:
Ok, I was just curious because my gtx 970 ftw never went above 40 c on idle. It's also quite loud when it does go up to 100% fan speed, is their anyone that owns this particular card, that knows of a good fan curve for it?
70c is a bit on the low side, try setting the fans to do 66% at 70 and ramp up to 100% at 80. Keep the temperature target at 83 so GPU boost doesn't throttle :)
Computer Specs:
Somewhere in the 65% range at 70C and 80-90 at 80C should do you fine. Idle temps seem a little high but the fans might be spinning really slow at 30%, I don't know. As long as your GPU doesn't really go over 85 I wouldn't be worried
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
Ok, I will take a look at that, thank you guys so much for all the help! :)
