Bildresultat för wall plug to lamp cable
this and a 80W lightbulb should do it
or you just get some good LED strips in white :)
Builds:
https://linustechtips.com/topic/686472-easy-way-to-light-pc/#findComment-8814403
3 minutes ago, Ronnie46 said:
i havnt found a easy way to light up the inside of my pc case just wondering if anyone knows of a product/way of easily lighting the inside of a PC.
- Ronnie
For plug and go LED kits Cable Mod or Bitfenix both make some good units. some others also such as Addon Customs, Modguru and Darkside also have good options.
https://linustechtips.com/topic/686472-easy-way-to-light-pc/#findComment-8814407
