Okay, so my issue right now is that the game is giving me terrible FPS outside, but inside I literally have almost 200 FPS. Now you might say that is because there is less going on outside and that would make sense but that is not the issue. I have found out that inside it is using 100% of my GPU but outside it is using as little as 5% at peak it uses about 75% that rarely ever happens. I need your help diagnosing this LTT forum
EDIT: sorry steam reset my screenshot settings so the pictures are compressed
  • CPU: AMD Ryzen 2700X
  • Motherboard: MSI X470 Gaming Pro
  • RAM: 32 GB HyperX Fury DDR4 2400
  • GPU: MSI 5700XT MECH
  • Case: Fractal Define R5
  • Storage: 1TB WD Black 7200 RPM HDD, 2TB WD Black 7200 RPM HDD, 4TB WD Black 7200 RPM HDD, Samsung Evo 960 1TB SSD
  • PSU: Corsair CX750M
  • Display(s): HP 24W
  • Cooling: 1 120mm Corsair fan, Noctua NH-U14S
  • Keyboard: Razer Blackwidow 2016
  • Mouse: Razer Deathadder Basilisk.
  • Sound: Razer 7.1 Kraken Chroma V2, LG SJ4Y 300W soundbar
  • Operating System: Windows 10 Professional 64 bit
https://linustechtips.com/topic/686447-skyrim-special-edition-fps-issues/
Is it too much of a problem to say that Skyrim SE is basically vanilla Skyrim with a touchup? None of the bugs got fixed so it's expected that the game has issues.
If you're certain you've done all you can on your end, like reinstall drivers and all that, then all that's left to blame is Skyrim itself. Because it's Bethesda, and they release buggy games.
Sounds like a cpu bottleneck, try lowering draw distance settings. It's not very cpu optimized.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
