I was just using my old external hdd and it was just so slow in doing things so i though i have to look into getting an ssd one you guys have any good suggestions at the $100 price range? 250gb around there i did see that samsung had there 250gb one with usb-c but thought i ask here i plan to use it with surface pro 4 so usb 3 not type-c
Needs Update
https://linustechtips.com/topic/686284-exturnal-ssd-help/
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
https://linustechtips.com/topic/686284-exturnal-ssd-help/#findComment-8812642
