I have it. It's not that bad.
My Pc: Cpu: I7 4790k @ 4,8 Ghz @1,25 volts, Motherboard: Maximus VII Formula, Graphicscard: 2x Titan X @1,4 at stock voltage (soon to be replaced), Ram: 32 gb Corsair Dominator Platinum 2133 Cl 9, SSD: 2x 850 Pro 1 Tb in Raid 0, 2x Samsung 840 Evo 1 tb raid 1,, PSU: Corsair HXi Series 1000W 80+ Platinum, Case: H440. Soon to be watercooled again, maybe, probably, the Titans are too loud.
Every time I install something it says smartscreen isn't working but I can install things anyways, other than that I haven't had any.
CPU: i5 4430 PSU: XFX 550w Ram: 8gb Patriot Viper 1600mhz
Motherboard: MSI H87M-G43 Case: Fractal Design Define R4
SSD: 840 Evo 250gb, 512gb MX100 GPU: MSI GTX 980TI Gaming Cooler: Hyper 212 Evo
Skydrive seems broken. At least to me it does. They removed the need of a desktop app, but the only way i can get it to sync up is upload the files via SkyDrive metro app. Adding the files to Skydrive from the desktop doesnt do anything, but adding it from the metro app does.
i7-2600K | ASRock Z77 Pro4 | ASUS 980 Ti Hybrid | Kingston 4x 4GB | EVGA Supernova 750 G2 Phantek Enthoo Luxe
Creative X7 Limited | 1TB WD Blue | 2TB WD Green | 256GB Liteon SSD | 240GB Kingston SSD | Corsair H100i
Logitech G502 Proteus Core | Logitech G710+ | LG 34UM65 | LG 27EA31V - B | AKG K7XX Massdrop | Windows 10 Pro 64-bit
my skydrive is fine and have not noticed the mouse glitch using (Roccat kova+)
One this that i really annoying is that you need a secure boot to be configure and my laptop does not have that in its bios ( even with Custom Bios installed ) so now i have water mark saying that i need to configure secure boot. can be disabled but then most of the Modern Apps don;t work. At lest it is just watermark on desktop not games and stuff :)
Needs Update
GeForce Experience will not work at all. Steam games work all the way up until you hit play in the main menu then crash to desktop. Corsair headset drivers are incompatible. Everything I have tried to reinstall.
Air 540, MSI Z97 Gaming 7, 4770K, SLI EVGA 980Ti, 16GB Vengeance Pro 2133, HX1050, H105840 EVO 500, 850 Pro 512, WD Black 1TB, HyperX 3K 120, SMSNG u28e590d, K70 Blues, M65 RGB.          Son's PC: A10 7850k, MSI A88X gaming, MSI gaming R9 270X, Air 240, H55, 8GB Vengeance pro 2400, CX430, Asus VG278HE, K60 Reds, M65 RGB        Daughter's PC: i5-4430, MSI z87 gaming AC, GTX970 gaming 4G, pink air 240, fury 1866 8gb, CX600, SMSNG un55HU8550, CMstorm greens, Deathadder 2013
I have mouse stuttering like @Coombzy said in games. Other than that my applications have no compatibility problems.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
I had Win8.1, to me somehow it looks different to Win8... So i fresh installed Win8 and dual booted Ubuntu :D
| CPU: INTEL i5 6600k @ 4.6Ghz @ 1.328v | Motherboard: ASUS Z170-AR | Ram: G.SKILL 2x8GB 2400Mhz | CPU Cooler : Corsair H100i V2
| GPU: GIGABYTE GTX980Ti G1 GAMING | SSD: SAMSUNG 840 EVO 250GB  Storage: WD 1TB GREEN | OS: Windows 10 Pro 64bit | PSU: FSP 650W AURUM S |
<<<<< BLK-Phant0m >>>>>
i want to update but before that i wanna ask if anybody has had any comptability issuse or anything like that and .thanks.
The biggest problem with Windows 8.1 is the fact that it is not Windows 7.
Desktop: Intel Core i7-6700K, ASUS Z170-A, ASUS STRIX GTX 1080 Ti, 16GB DDR4 RAM, 512 GB Samsund 840 Pro, Seasonic X series 650W PSU, Fractal Design Define R4, 2x5TB HDD
Hypervisor 1: Intel Xeon E5-2630L, ASRock EPC612D8, 16GB DDR4 ECC RAM, Intel RT3WB080 8-port RAID controller plus expansion card, Norco RPC-4020 case, 20x2TB WD Red HDD
Other spare hypervisors: Dell Poweredge 2950, HP Proliant DL380 G5
Laptops: ThinkPads, lots of ThinkPads
Broke my sata controller drivers, had to wipe my entire os partition, but no big deal... :/
 i7-4770K, Corsair H100i, Asus Maximus VI Hero, Corsair Vengeance Pro 16GB, Samsung 840 120GB, 2xSeagate Barracuda 1TB, EVGA GeForce GTX 780 ACX Cooler, NZXT Phantom 820, Corsair Professional 750W 80 PLUS Gold, 2xASUS VH238H Build Log- http://bit.ly/1bWZKu6
I am looking into win 8.1 for my new system but like any new iteration  of windows it comes down to a reworking of your hardware & software before you can get it to work that's why for right now I am sticking with win 7 until they get it all settled
That's because you enabled it during the setup of your account. You can turn it off in the Control Panel.
But if you want it, all you have to do, is click on "More details", then you'll see a button "Run anyway", and this will white flag it for you, and will add a vote for it on Microsoft database that it's safe... if many says it's fine, Microsoft will validate it, and if that passes, the message won't show up.
It only shows on non digitally signed programs. Many programs don't do this, as it's thousands of dollars to do.
The biggest problem with my electric car is the fact that it doesn't run on gasoline. Then perhaps you should have bought another car, eh?  ;)
I did buy another car, so to speak.  Except I never bought the first one.
Mouse issue with many games, it's pretty horrible when playing games that require a lot of movement.
Desktop: Intel 4770k - 12GB Vengeance Pro 1866Mhz RAM - Asus Maximus VI Formula Mobo - Asus Strix 970 SLI - Cooler Master V850 PSU -  Nzxt Phantom 630 Case  - 1TB WD HDD - Samsung 840 Evo 250GB SSD - Nzxt Kraken X60 - 24" Asus VG248QE 1080p Monitor - Logitech G35 Headset -  G502 Proteus Core - Logitech G710+ Keyboard - Nzxt Hue - Windows 10
They each have their pros and cons.  :)
Yes, it's just a matter of determining whether the pros outweigh the cons in each individual case.
I tried to install it several times on my new rig and it was terrible..
The first two times when the system rebooted I had to give my password but when I entered it, it wouldn't recognise it
So I reset the computer, the first two times it would just restart windows 8, but when I kept trying to install the update, the system would crash and have problems with restarting afterwards. The last time I tried it took more than half an hour before the system would get past the password screen without crashing.
I don't know if I'm the only one with this problem but it scared the hell out of me so I'll stay with W8
