neither build actually. what is your budget?
EDIT: I am going to guess 900-1k
CPU-i7 6700k O.C. 4.6Ghz-Motherboard-Asus z170-a-RAM-24gb DDR4-GPU-EVGA GTX 1080 FE-Case-Corsair 400c (white)-Storage-HDD: 2xWD Blue 1TB SSD: PNY SSDSC120GLC709B121-510 120GB-PSU-1000 watt coolermax-Display-ASUS VG248QE Black 24" 1080p 144 Hz -Cooling-Corsair H115i-Keyboard-G.Skill KM780 Cherry MX blues (Red backlight)-Mouse-Logitech G602-Sound-Logitech 5.1 z506
Need a budget headphone for under 100$? Sennheiser HD 558 Headphones
Got a Skylake CPU (k) Here is a guide to OC it!
https://linustechtips.com/topic/685465-help-with-build/#findComment-8804299
You should take the one I made for you :P
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/685465-help-with-build/#findComment-8804310
you peaked my curiousity?
https://linustechtips.com/topic/685465-help-with-build/#findComment-8804315
if you can live with your current monitor, mouse and keyboard here:
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($240.98 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($27.97 @ Newegg)
Motherboard: MSI Z170A Tomahawk AC ATX LGA1151 Motherboard  ($112.98 @ Newegg)
Memory: Corsair Vengeance LPX 8GB (2 x 4GB) DDR4-2400 Memory  ($47.99 @ Newegg)
Storage: A-Data Premier SP550 120GB 2.5" Solid State Drive  ($38.99 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.49 @ OutletPC)
Video Card: MSI GeForce GTX 1070 8GB Video Card  ($404.99 @ SuperBiiz)
Case: NZXT S340 (Black/Red) ATX Mid Tower Case  ($66.99 @ SuperBiiz)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($59.99 @ Newegg)
Total: $1033.38
Generated by PCPartPicker 2016-11-03 19:47 EDT-0400
also to add there is a promo on the motherboard [MOBO] MSI Z170A TOMAHAWK AC LGA 1151 Intel Z170 HDMI SATA 6Gb/s USB 3.1 ATX - $99.99 ($149.99 - $40.00 - $10 rebate card) from build a pc sale
https://linustechtips.com/topic/685465-help-with-build/#findComment-8804347
Ok spent a lot of time with this, got it right in the budget with 6600K, 16GB ram, G2 PSU and 1060 6GB, with some colour matching!
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($236.98 @ NCIX US)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.88 @ OutletPC)
Motherboard: MSI Z170A KRAIT GAMING 3X ATX LGA1151 Motherboard  ($112.98 @ Newegg)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($93.99 @ Newegg)
Storage: Crucial MX300 275GB 2.5" Solid State Drive  ($69.98 @ B&H)
Video Card: EVGA GeForce GTX 1060 6GB 6GB GAMING Video Card  ($239.99 @ Newegg)
Case: NZXT Source 210 (White) ATX Mid Tower Case  ($39.88 @ OutletPC)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($59.99 @ Newegg)
Monitor: Acer KN242HYL 23.8" 60Hz Monitor  ($110.98 @ Newegg)
Keyboard: Cooler Master OCTANE Wired Gaming Keyboard w/Optical Mouse  ($29.94 @ Newegg)
Total: $1069.08
Generated by PCPartPicker 2016-11-03 19:49 EDT-0400
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/685465-help-with-build/#findComment-8804364
Total: $1069.08
the fury x is a better card fyi though 1060 does have more VRAM sooo it is a toughy tbh
https://linustechtips.com/topic/685465-help-with-build/#findComment-8804374
Fury X also costs quite a bit more too unfortunately and the X HBM memory is probably more efficient anyway
Ryzen Ram Guide
https://linustechtips.com/topic/685465-help-with-build/#findComment-8804381
https://linustechtips.com/topic/685465-help-with-build/#findComment-8804383
WAIT I LIED enter promo  (-$25) Amex Promo it will cost a total of $244.99 thank the internet for buildapcsales
https://linustechtips.com/topic/685465-help-with-build/#findComment-8804392
In that case put that Fury X in my build!
Ryzen Ram Guide
https://linustechtips.com/topic/685465-help-with-build/#findComment-8804406
eh still on the fence like the fury x is  only what 10% better but you do not get 6gb of VRAM which is interesting... soooo at this point its fps/$$
https://linustechtips.com/topic/685465-help-with-build/#findComment-8804420
But the HBM is much more efficient, it gets better the higher res =)
Ryzen Ram Guide
https://linustechtips.com/topic/685465-help-with-build/#findComment-8804427
I know! but eh still torn. though at this point its coming down to the OP doing 1080p gaming. Which I encourage the OP to save up for a 144hz screen.
https://linustechtips.com/topic/685465-help-with-build/#findComment-8804437
Get the XFX Fury X, better cooler and for AMD cards it goes something like this:
MSI>ASUS>XFX>Sapphire>Reference>Powercolor
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
https://linustechtips.com/topic/685465-help-with-build/#findComment-8804486
