Hey LinusTech-Community,
so i am about to get a new pc. Thats what i planned.
Everything should fit in a Nanoxia Deep Silence 3 Mid Tower:
Intel Core i7 6700K 4x 4.00GHz So.1151
MSI Z170A GAMING PRO CARBON Intel Z170 So.1151 Dual Channel DDR4 ATX Retail
LEPA AquaChanger 1x120mm AIO Liquid Cooler
600 Watt be quiet! System Power 8 Non-Modular 80+
16GB G.Skill RipJaws V red DDR4-3000 DIMM CL15 Dual Kit
MSI V320-034R GF GTX 960 Graphics Card NVIDIA (PCI-e 4096, GDDR5, PCIe 3.0 x16 1 GPU)
Samsung EVO 250Gb
Greetings from Germany,
Shixsore
https://linustechtips.com/topic/685382-will-it-work/
3 minutes ago, Shixsore said:
-snip-
Welcome to the community.
The build looks good, but I have to ask why you are going with the i7 and a 960?
I would definitely go with the i5 and a better gpu like the 1060 or something.
When in doubt, re-format.
https://linustechtips.com/topic/685382-will-it-work/#findComment-8803301
You should get something other than a 960. Also, consider getting a better PSU, like a semi modular Seasonic unit.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/685382-will-it-work/#findComment-8803357
tbh, i allready got the graphics cards month ago since my old one broke.
budget is about 780€, but i got the graphics card and ssd allready. (sorry did not mentioned it)
i picked the i7 to be prepared if i upgrade my graphics card at some day.
im running a ~5 years old AMD low budget system atm, and would just be happy if i can play my favorite titles at decent fps.
https://linustechtips.com/topic/685382-will-it-work/#findComment-8803622
I wouldn't bother with an i7, and would save that money so that you could upgrade the GPU in the future. Any new GPU will give you a much better experience than an i7 would over an i5.
Other than that the build is pretty good. The PSU youre looking at is a good one, just not modular, so you may have to hide cables in your case. Not a big deal depending on now "showcase-y" you are trying to get with the computer.
https://linustechtips.com/topic/685382-will-it-work/#findComment-8803916
Aight, thank you guys for the help.
Guess i will still go with a i7, since i bought my gpu 2 month ago and I thought its not a bad buy. Not planing getting a new Gpu in near future.
Just to make sure for my future, which gpu is a good pick for the i7? Is there a big difference in a more powerfull gpu picture wise?
https://linustechtips.com/topic/685382-will-it-work/#findComment-8806069
Literally and 10XX series NVidia card will be an improvement over a 960. That being said, the 960 is still decent enough for 1080p gaming, and any single future card released by Nvidia will be a nice bump in performance. So at least you have an upgrade path a few years down the line. As far as a worthwhile upgrade in the future, only the future knows.
https://linustechtips.com/topic/685382-will-it-work/#findComment-8807300
