This is my first build and i want help with the selection of cabinet + cooling solutions in it except the cpu and would this build require a custom thermal paste?
And at last will this build hold up in the near future according to you?
Note -
1). i reside in India thus there would be some import duties + some inflation as well though here a 1000$ build  made up in US can reach up to 1400$ build made in India
2). This budget is not for the peripherals or monitor
https://linustechtips.com/topic/685146-first-build-help-required/
Note -
what's your budget in Rupees
Can you not get a 4x8GB set of G skills ?
But anyway a that pretty similar to my build except I use a H80i V2
terms of custom thermal paste, the H100i has a pre applied layer of Corsair's custom thermal paste
case selection, with what you've got, any standard sized mid tower +  will work, so it's up to you to pick one you like,
cooling, well depending on how many preinstalled fans, you wouldn't be needing much, just enough to comfortable pull air in and. Push it out
build should last you many Years going forwards
Note - i reside in India thus there would be some import duties + some inflation as well though here a 1000$build made up in us can reach up to 1400$ build in india
The budget would be 1,50,000
3 minutes ago, Gursimran 82956 said:
That
That 1400$ was used as an example
my bad.
Case- Phanteks Enthoo Pro M
AIO cpu cooler- Corsair h100i v2
You don't need to apply thermal paste on anything, it comes pre-applied aio cooler & this build is definitely future proof but if you want the latest then you have to wait for a couple of months for the kaby lake architecture (i7 7700k). But the performance difference won't be huge.
Would a corsair carbide spec alpha cabinet work?
As i don't know if these things would fit or not?
PCPartPicker part list: http://pcpartpicker.com/list/Wq3hjc
Price breakdown by merchant: http://pcpartpicker.com/list/Wq3hjc/by_merchant/
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  ($174.99 @ SuperBiiz)
Motherboard: MSI B150M MORTAR Micro ATX LGA1151 Motherboard  ($67.98 @ Newegg)
Memory: Crucial Ballistix Sport LT 8GB (1 x 8GB) DDR4-2400 Memory  ($42.99 @ Newegg)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive  ($61.99 @ NCIX US)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($47.33 @ OutletPC)
Video Card: Gigabyte Radeon RX 480 8GB G1 Gaming Video Card  ($250.99 @ B&H)
Case: Corsair SPEC-01 RED ATX Mid Tower Case  ($39.98 @ Newegg)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($49.99 @ Newegg)
Total: $736.24
Generated by PCPartPicker 2016-11-03 07:46 EDT-0400
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
37 minutes ago, Tim Serious said:
check the specs of alpha
34 minutes ago, JamieOlive said:
https://pcpartpicker.com/list/
That would be an awesome build and a beautiful one at that, around $1600, making it last easily for at least 3 years.
52 minutes ago, Sahil10416 said:
my bad.
Thanks for all the help now my last question would be if the corsair h100i v2 would work efficiently or not in this cabinet
Cabinet review- https://www.google.co.in/amp/www.techspot.com/amp/review/1169-corsair-carbide-spec-alpha/?client=ms-android-vf-it
Total: $736.24
funny?
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
I wouldnt build in that case, i don't find it good looking but that's just personal, and it may be able to fit maybe not it says it takes 240mm radiator but i wouldn't stretch it that much, but something along the NZXT S340 ELITE or the Fractal Dsign Define S or Corsair Carbide 400C would be much better options aand they are not expensive around 70-100 depending on the region.
51 minutes ago, Gursimran 82956 said:
The budget of pc build to be made was approx 3 times the budget pc build you made
Thanks anyways
yes ik but things in asia can cost way more than that.
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
Thanks anyways
2 minutes ago, Tim Serious said:
it is bad but not that bad ??.
PCPartPicker part list: http://pcpartpicker.com/list/h6dKhq
Price breakdown by merchant: http://pcpartpicker.com/list/h6dKhq/by_merchant/
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($328.99 @ SuperBiiz)
CPU Cooler: Corsair H115i 104.7 CFM Liquid CPU Cooler  ($124.99 @ B&H)
Motherboard: Asus SABERTOOTH Z170 MARK 1 ATX LGA1151 Motherboard  ($239.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2666 Memory  ($82.99 @ Best Buy)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($94.89 @ OutletPC)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($73.80 @ OutletPC)
Video Card: Asus GeForce GTX 1080 8GB STRIX Video Card  ($724.98 @ Newegg)
Case: Corsair Air 540 ATX Mid Tower Case  ($121.99 @ NCIX US)
Power Supply: Corsair RMx 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ Newegg)
Total: $1892.61
Generated by PCPartPicker 2016-11-03 10:47 EDT-0400
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
Total: $1892.61
Thanks?
1 minute ago, Gursimran 82956 said:
Thanks?
np, sorry for underestimating your budget
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
31 minutes ago, Gursimran 82956 said:
It costs exactly 2327$ US here from newegg+amazon India but still its good
don't buy from Amazon india ....... their price is stupidly high.
where you live in india? ..... if you live in metro cities you can find stores which sell pc parts, there u can find some good deals, for ex. if you live in delhi go to nehru place and if you live in mumbai go to lamington road.
if you can't buy offline then buy from ....
primeabgb.com
mdcomputers.in
itdepot.com
golchhait.com
itwares.com
newegg would also be not a good idea as u have to pay a lot of shipping charges
also i would suggest you to go to r/IndianGaming if you are on Reddit as i have seen many people post their builds there, like yours, so they will surely help you where to find good deals.
2300$ is a lot for 1400$ build.
primeabgb.com
mdcomputers.in
itdepot.com
golchhait.com
itwares.com
I live nearby Chandigarh
And thanks for the websites
