Hello all,
Yesterday my internet was working.
Today i turn on my pc, no video output, i reset cmos and it works again. Then the next problem arises.. My ethernet port isn't being detected.
I have tried the following:
Uninstalling via device manager (this now also caused that i can't see the driver, even when showing hidden drivers)
Updating LAN drivers
Resetting cmos.. again
Checking bios for disabled lan
I can't flash the bios, because it is already the newest version.
Specs:
I7 870
Asus GTX 750 TI
Motherboard: Foxconn H55MS W/ Realtek LAN
please help
https://linustechtips.com/topic/684776-ethernet-not-recognised/
11 minutes ago, Dispentry said:
Hello all,
Specs:
I7 870
Asus GTX 750 TI
please help
How are you updating your LAN drivers when the port isnt functioning? Your are not
On a seperate device, download and install the drivers onto a USB drive, plug that into your pc, then manually install the drivers, chooseing the usb drive as the location to install the drivers from
Roses are red
My name is Roy
We caught the alligator that ate the De Luca boy
https://linustechtips.com/topic/684776-ethernet-not-recognised/#findComment-8796644
thats what i did though :( It says the network adapter wasn't found, and that if it is in deep sleep mode i should plug in my cable
https://linustechtips.com/topic/684776-ethernet-not-recognised/#findComment-8796767
