So i've been thinking about getting a GTX 1060 6GB and just need to know whether my parts will bottleneck the 1060 and if my PSU will supply enough power and safely.
Specs:
- Asus GTX 960 4GB
-8GB RAM
- Intel i-5 6600 3.30 GHz
-Corsair VS550 PSU
Also, if anyone knows a good place I can sell my 960 and how much it would go for? (AUD)
https://linustechtips.com/topic/684653-need-some-help-8/
No.
And probably not too much, probably around 200?
https://linustechtips.com/topic/684653-need-some-help-8/#findComment-8795125
7 minutes ago, NunterHing said:
So no it won't bottleneck? or no I won't have enough power?
No bottleneck, PSU should be fine.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/684653-need-some-help-8/#findComment-8795167
No man i would not bottleneck it at all, but if you want to game at 1440p i would suggest a 16Gb Ram (The same ones), along with a SSD, if you dont already have one.
But i wouldnt personally go from 960 to 1060, i mean its one hell of an upgrade but not that much in my opinion, think about it and i hope i helped.
https://linustechtips.com/topic/684653-need-some-help-8/#findComment-8795172
y the ssd for 1440p? storige does not improve performance at all! only loading times. and he does not mention 1440p at all at any moment so i take it he just plays 1080p and so a 1060 will be perfact
https://linustechtips.com/topic/684653-need-some-help-8/#findComment-8800293
