I´m thinking about making my pc and the specs are the folowing:
Intel core I5 4690
16 gb kingston hyper x
MSI geforce GTX750 TI
MSI B85M-G43
COOLER MASTER Seidon 120V V2 Liquid Cooler
SEAGATE 1TB SATA III 64MB 7200 RPM
1LIFE ps:jet 600W
If the specs are good please tell me if not tell me as well
hopefully the specs are good
I just want the pc to play games such as:
-black ops 3,2,1
-Metal gear 2 substance
-Gmod
And so on...
The budjet for this pc that i want to spend is arround 900 $ (in euros are 850~) so.. thank you for your time
https://linustechtips.com/topic/684282-help-mee-making-my-pc/
In my opinion you should upgrade your graphics card to something which is more modern, Maybe something like a GTX 1050TI or a 1060 3GB as you didn't need that powerful of a card to play the games you listed. Apart from that this is a pretty good build. I
MochPot: AMD Ryzen 5 2600, 16GB 3200MHz DDR4, ASRock X370 Fatality K7, 8GB Nvidia GeForce GTX 1070, 256gb Salvaged Intel Rando NVME SSD, Corsair RM750x, Corsair Carbide 275R, Windows 10 Pro
ZenServerRequiem: AMD Ryzen 3 2200g, 32GB 3200MHz DDR4, MSI B450 Gaming Plus, 4GB Nvidia GeForce GTX 960, 2GB Nvidia Quadro P400, 500gb Salvaged Intel Rando NVME SSD (Cache Drive only), 3 x Seagate Baracuda 2TB, Corsair CX500, Corsair Carbine 750T, Limetech Unraid (Running Plex, Jackett, Sonarr, WireShark, Duck DNS, Ubuntu Server VM for MC server)
https://linustechtips.com/topic/684282-help-mee-making-my-pc/#findComment-8790581
get a gtx 1050 instead of a 750TI. get a i5 6500 processor + h110/b150 motherboard. get a different power supply.
getting a 1050 is about the same price and performs alot better.
its probably better to get a i5 6500 instead of i5 4690 because if you want to upgrade your processor you will have to replace your motherboard if you buy a i5 4690. keep in mind you need DDR4 if you get a i5 6500.
the EVGA 500b/CX500 are cheap and reliable power supplies from a good brand.
Personal build >  New-ish AMD main gaming setup
   PLEASE QUOTE OR @ ME FOR A RESPONSE xD
https://linustechtips.com/topic/684282-help-mee-making-my-pc/#findComment-8790628
Ok here are the new changed specs
cpu Intel core i5 6500
2 crucial 4 gb ddr4 2133mhz
Kingston ssd hyperX fury 120 gb ssd
CORSAIR VS550W VS Series
MSI B150M NIGHT ELF
MSI GTX 1050 TI
what do you think?
Origanly the other config costed 800 euros the new is 827 so Huge diffrence thank to your comment and sugestions
Edited by diogo_the_man
https://linustechtips.com/topic/684282-help-mee-making-my-pc/#findComment-8790942
MSI B150M NIGHT ELF
what do you think?
you cannot overclock that processor, liquid cooling isnt needed. the processor is packaged with its own cooler.
https://linustechtips.com/topic/684282-help-mee-making-my-pc/#findComment-8790994
1 minute ago, Ephy said:
1050W is overkill, he can't overclock the Processor, I would go with 750W max, just in case you want to upgrade later on
he meant the GTX 1050.
https://linustechtips.com/topic/684282-help-mee-making-my-pc/#findComment-8791068
2 minutes ago, diogo_the_man said:
So... i cannot use intel turbo boost technology? i just want the liquid cooler just so it perfoms better and im not a big overclocker so.. overclocking a cpu is defenetly not for me
you will get the turbo boost regardless of if you overclock or not, overclocking is just manually increasing the speed of your processor, but that usually heats it up.
if you are not overclocking, your processor will perform the same if you get liquid cooling or not.
https://linustechtips.com/topic/684282-help-mee-making-my-pc/#findComment-8791078
Since u can't overclock, the Stock Cooler schould suffice;
If it has Turbo Boost Technology it will use it,
and the reason to get a Liquid Cooler on ur build is for the Looks
https://linustechtips.com/topic/684282-help-mee-making-my-pc/#findComment-8791083
i want that gpu beacause im going to use two screens and i need one gpu that is +/- cheap and good for two screens-
and i still going to use the water cooler just for looks and better perfomance ( i know that liquid coolers are used more often for overclocking but i dosent have to be JUST for overclocking so..
https://linustechtips.com/topic/684282-help-mee-making-my-pc/#findComment-8791106
Are you playing on the two monitors at the same time?
https://linustechtips.com/topic/684282-help-mee-making-my-pc/#findComment-8791137
Forget the old specs now im talking about the new ones hope fully the gtx 1050 ti is enough
1 minute ago, Megah3rtz said:
I wouldn't even think the gtx 1050/1050ti is powerful enough either.
if you're running 2 monitors playing the same game at the same time buy a gtx 1060 6gb/gtx 1070.
https://linustechtips.com/topic/684282-help-mee-making-my-pc/#findComment-8791188
